Cobra sqeaks.........ALOT
Old July 10th, 2008, 07:15 PM   #1
The Doctor
Lefty's Avatar
'01 Cobra Vert.
iTrader: 11 reviews
I don't know if this should go into the convertible category or here. My cobra vert sqeaks a lot. Will subframe connectors fix this problem?
Old July 10th, 2008, 11:48 PM   #2
68 dlxcoupe's Avatar
2004 Mach 1
13.30 @ 104.47
68 dlxcoupe is on a distinguished road
Send a message via AIM to 68 dlxcoupe
When does it squeak?? Is it during driving? if so acceleration, deceleration?? What about when you get in and out of the car?? Can you make it squeak by going to each corner of the car and bouncing it?? If so I would say something with the struts or possibly the strut bearing.........just my .02
http://www.moonshine-media.net/68dlx2.jpg
EAGLE SCOUTS OR GTFO
MyStangOpens (12:01:05 AM): honey nut for me
Old July 11th, 2008, 09:22 AM   #3
The Doctor
Lefty's Avatar
'01 Cobra Vert.
iTrader: 11 reviews
it sounds like suspension....and the brakes squeak a shat load too....not even when i'm on them...sometimes they squeak when i go around a turn and its loud as crap....and sometimes i get squeaking from, what it sounds like, is the rear end....i don't know if the springs and everything back there just need to be oiled up or what not
Old July 11th, 2008, 07:35 PM   #4
2004 Mach 1
13.30 @ 104.47
It wouldnt surprise me if it was some part of the suspension. Everything pretty much flexes in the car when driving. When you turn you put weight against the wheels which in turn flexes the rotor just enough to make contact with the pad. This happens to me all the time in my Mach 1 with the RR wheel. Other than that, just try and locate the general area of the noise and goin in there with some WD-40
Threads Similar to: Cobra sqeaks.........ALOT
hotter and ALOT louder ok? DeMello 99-04 48 June 10th, 2008 03:13 AM
So we were drinking (alot) and we think... WAR-PARTY The Clubhouse 8 May 13th, 2008 03:27 PM
Alot Of Research (Cams) mustang fanatic 2005 - 2010 20 November 25th, 2007 09:52 PM
uv heard this alot but... machine_008 V6 Mustangs 1 November 13th, 2006 08:08 PM
