Discussing Start up in the 4V / SVT Forum. I will try to simplify or make this easy for one to diagnose. As the ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
2003 Ford Mach
Traveling at the speed of a photon
Start upAs the title states, I took the Mach out for a spin (50miles or so). Came home and parked it. I Noticed it needed a wash, so i went in and tried to start the car, but it hesitated with the start up or as if there wasn't enough spark to start the car and eventually died. I tried it again, but this time i gave it some gas and "what do you know" it started. This is new to me. The plugs were recently changed a week ago. Could this be something else that needs my immediate attention? Keep in mind that i have no tune with several mods that require one....lol (My fault) Could that be the answer? Any information is greatly appreciated at this moment
![]() Under my Umbrella! Studies show that 99.9% of the kids on MM ask the same questions over and over again about performance parts yet do nothing after the advice is given because they're still in Highschool and suffer from no money syndrome. |
2003 Mach 1
what did the plugs look like? is the car running too rich?
Project N/A 4V Under Way |
2003 Ford Mach
The tip of the plugs had a minor rust color but nothing too serious. It could've been water that is no longer there. The plugs were black and gray. Like i said i have a JLT ram air, Bassani high flow X magnaflow weld ins and pulleys and have no tune. Could that be it?
2003 Mach 1
That stuff doesn't realy require a tune. It would be helpful though. I have seen more stuff on a car with no tune and not have problems like that. when you are "givin it gas'' you are just opening the throttle blade, you aren't actualy adding more gas like in the carburated cars.
#5 | |
2003 Ford Mach
2003 Mach 1
How long has it been since you changed the fuel filter?
1999 SVT Cobra
14.5601@96.33
you could try different spark plugs mayb, if this just happened and the spark plugs were changed not long ago either it could be that. same thing happened with my jet ski today ( i know completely different so i dont want to here how its not teh same) but i changed teh spark plugs and it started just fine.
1999 SVT Cobra
14.5601@96.33
just an idea...
2003 Ford Mach
Changed it about 8k ago. Could it be that it needs replacement after cleaning the fuel injectors with Lucas gas treatment? I'm more confused than a child lost at chuckee cheese...lol The car runs great and it's a "stay at home" vehicle.
03 mach 1
13.2@109
did you listen for the fuel pump? you can always try the old trick of taking off the gas cap and sticking a pen to open the lid and having someone turn the key, even if it turns on, check the fuel pressure maybe its going or getting to hot etc. not sure if thats it but its something to try.
#11 | |
2003 Mach 1
Its possible the lucas got all the gunk out of the tank to move on down the line to the filter. Its worth a shot and its a cheap part. Try that and if it doesn't fix it then you will have to do a little more trouble shooting. But if it fixes it you haven't wasted a bunch of time.
Mtn. Bike
8.14@198.98MPH LOL
-97cobra
you might also want to check to see if you pushed the coil on good enough. make sure one isnt loose. |
#13 | |
2003 Ford Mach
#14 | |
2003 Ford Mach
03 mach 1
13.2@109
I've heard of Lucas gunking filters up. If you have the tool check fit pressure before buying one
#16 | |
03 Mach 1--~--1 of 2513
8.9 1/8 mile time
![]() -Josh- 2003 Torch Red Mach 1 Originally Posted by HMUSN it's like racing a mach 1 .. not untouchable but still gonna lose plain and simple no matter how you roll the dice. |
Threads Similar to: Start up
| will it start, or no??? | oscrfsh | 5.0 Mustangs | 10 | March 11th, 2008 08:00 AM |
| where to start | EasyE64 | V6 Mustangs | 63 | September 25th, 2007 02:50 AM |
| first start | skid6 | 5.0 Mustangs | 2 | August 3rd, 2007 06:54 AM |
| 5.0 won't start | polish95mustang | 5.0 Mustangs | 15 | April 22nd, 2007 11:43 PM |
| won't start =-( | wesbugg | 96-98 | 2 | January 29th, 2007 06:58 PM |
