Discussing Rear Brake Tool in the 4V / SVT Forum. I was about to change my rear brake pads today when right before I was ...
Old July 14th, 2008, 07:32 PM   #1
Mach Boy's Avatar
2004 Mustang Mach 1
13.81@104.11
Rear Brake Tool
I was about to change my rear brake pads today when right before I was about to do it I was told I would need a "special" tool. Anyone know what this is? I was told I could get the old pads off but putting them back on would be impossible without it.
302rwhp 321tq
Old July 14th, 2008, 07:36 PM   #2
prodrifterx's Avatar
1999 Mustang Gt
14.592 @ 95.44
true....you can buy the true kit genius....yet you can go to sears or advanced and get this square tool....it has 2 dowels on each side of the block and you put a 3/8" ratchet on it so that you can trun/twist the caliper piston back in place. should be like $10 for that small item...its 80 or 150 pending the full kit you buy...i just boguht one for work that does bidirectional for european cars. the $80 kit..if you were to buy it is sufficient as is the small block tool alone....will post pic of the small tool i am speaking of.
examples
Vehicle Service, Wheel & Brake, Miscellaneous Brake Service Tools | Matco Tools Online Tool Catalog
part number/code number----mst55a
part number/code number-----db25
i have this at home:
i have the bigger version of the db25 at work.
Originally Posted by Fryrice View Post
You cant buy horsepower off a Autozone shelf. If you wanna play you gotta pay.
{FlowMaster A.T., MAC CAI, MGW Short Shifter, 17" GT Wheels, 255/45ZR17 Cooper 2XS, SLP Underdrive Pullies, SLP 180 Thermostat, Many Cosmetic Upgrades}
Old July 14th, 2008, 07:38 PM   #3
Mach Boy's Avatar
2004 Mustang Mach 1
13.81@104.11
Thanks a lot. He also said there was a piece that I could buy for the ratchet so that must be what you're talking about.
302rwhp 321tq
Old July 14th, 2008, 07:39 PM   #4
MATT02GT's Avatar
The tool is sold at most parts stores. It looks like this:Disc Brake Piston Tool ATD-5060 The rear pistons have to be screwed back in rather than pressed like the fronts. Sometimes you can use needle nose pliars to do the job.
Old July 14th, 2008, 07:45 PM   #5
1999 Mustang Gt
14.592 @ 95.44
editted and updated my post with pix and links.
Old July 14th, 2008, 07:46 PM   #6
commandersafi's Avatar
2000 v6 Mustang
You don't have to use any of those tools. To push the brake piston back in just use a c-clamp and push it in. I've done it before and it works just fine
MM Chat Crew Leader
atlacatl213: i found it funny how she wanted you to attack lmao.
atlacatl213: like if you were some sort of pokemon
atlacatl213: safi i choose you!
"It's better to be a pirate than to join the Navy" -Steve Jobs
Old July 14th, 2008, 08:39 PM   #7
99 Cobra
you must be talking about the fronts cause on the rears it states that you have to screw them back in and thus why they have the indentations on them.
Old July 14th, 2008, 10:10 PM   #8
MATT02GT's Avatar
Dont listen to this guy
Old July 14th, 2008, 10:30 PM   #9
July 08 ROTM
futureMACH1racer's Avatar
2004 Mach 1
Too Slow
I've always just used a C clamp as well. Then again, I've never changed my brake pads either.
MM MACH 1 CREW MEMBER #2
McCain/Palin '08
Arsenal0328 (10:32:19 PM): mso gives me a raging hard on
Old July 14th, 2008, 10:37 PM   #10
Garhfer's Avatar
2004 Mustang GT Conv.
If you get the cube tool you might need to file out one of the pieces that stick out, it wasn't spaced enough to fit into my rear ones so I used a dremel tool and just filed it out a little bit and worked perfect. And any part store should have that cube, it was on the racks at Advance Discount when I bought mine.
2004 GT Boosted by Vortech
Old July 14th, 2008, 10:49 PM   #11
Mustang RacR94's Avatar
03 mach 1
13.2@109
well its half right
You can do what everyone I know does. Which is just take a pair of needle nose pliers and put them in the channels and turn the piston. The pliers will slip out ever 3/4 of a turn usually and can be annoying but its easily do able with no tool. I've never used one
But the down fall is over time they can get a little stripped and get to be annoying
Just use the needle nose pliers. Line the prongs up in the channels and turn them to the right. And if you wanna know for the front I just turned the pad around and put a c clamp in the middle of the pad and squeezed. That ensured both pads went down evenly
2003 Mach 1, 5 speed
MM MACH 1 CREW
www.myspace.com/mustangracr94
Old July 14th, 2008, 10:55 PM   #12
Rico-mofos's Avatar
2004 mustang GT
i just put on new rotors and pads on the rear...just get the square tool thing it makes life easier! ive done alot brakes but i never had to use this tool until now...and im sure i would have been able to figure out a way without it but i probly would have had some bloody knuckes and been very pissed off
You have to work up to it slowly.
After a few months of thumbing/fingering/rubber booting her anus, you're ready to ask her if you can attempt anal.
Old July 14th, 2008, 11:38 PM   #13
1999 Mustang Gt
14.592 @ 95.44
yea you can use pliers and such...it all depends on how hard it is to turn...some are easier than others for no apparent reason....but regardless know that with an integral park brake design in the rear calipers makes it so that one must rotate the piston back in...currently clockwise...and a c clamp or large vise grips or w.e. works fine for the fronts.
and this only applies to the fronts for these M.Y....older design mustangs probably had that style....yet not new design (sn95 or s197)....yet many current vehicles still have separate park brake and rear brake assemblies so one can still use c clamps and such like one does for the front....example would be like a tahoe or impala....i believe only the malibu, hhr, and cobalt have integral currently on gm models. (sorry gm tech here)
Old July 15th, 2008, 12:13 AM   #14
Mach Boy's Avatar
2004 Mustang Mach 1
13.81@104.11
I've already did the fronts but all that was required for that was the compressor. I didn't have time to do the rears at that time.
302rwhp 321tq
Threads Similar to: Rear Brake Tool
Rear Brake tool 04DSGV6 Brakes 11 September 9th, 2008 10:48 PM
Rear brake and Rotor 97GSTANG Brakes 2 July 6th, 2008 09:22 AM
Rear brake kits? 86ttops 96-98 11 May 24th, 2008 09:38 PM
Rear brake hoses? Dj1123 V6 Mustangs 3 May 24th, 2007 03:16 PM
Rear Brake Questions Jojogunne 5.0 Mustangs 2 March 23rd, 2007 11:13 AM
