Discussing Rear gear...speedo off!!! in the 4V / SVT Forum. I put this in the drivetrain category as well... Alright here is what I have......
Old July 14th, 2008, 08:06 PM   #1
matted2thefloor's Avatar
99 Cobra
13.77 @ 102
Alright here is what I have...a speedo that is way off even after programming with a handheld!!!
I'm running a T-56 Cobra spec with a 3.73 rear gear on a 295 rear tire. After many hours of searching and plugging in numbers into a gear chart, I have concluded by looking at the chart going by the displayed speed reading on the speedo at the given RPM in a given gear, it looks like 4.30 gears match the speed that I am going. Would I be able to program the car to the 4.30 gear and have the speedo be closer to accurate? Or would that just be wasting my time? For instance...I'm running 44 mph on the speedo at 2500 in 4th gear. Looking at the 3.73 calculations in the chart the speedo should be reading 52 mph. If I plug in the same tire, gear and trans ratios...4.30 gear is closest to what the speedo is reading!!!
The car has been going a good while like this and I just want to get it close to accurate as I can to keep mileages and such inline...not to mention I don't want a speeding ticket either!
Any insight or help would be appreciated!!!
99 Cobra, T-56, Spec Stage 3, aluminum driveshaft, MGW shifter, shorties, X, FM Amer. Thunder, 3.73, SRA, FR500 18s, JLT RAI, Tokico struts, adjustable UCA's/LCA's, H&R Rear Springs
Old July 14th, 2008, 08:49 PM   #2
ECUSVT31's Avatar
1999 SVT Cobra
14.36@98.46
i realy dont wanna get off subject, but quick question, how do you like your mgw shifter?
Old July 14th, 2008, 08:49 PM   #3
July 08 ROTM
futureMACH1racer's Avatar
2004 Mach 1
Too Slow
Get a tuner, that should correct the speedo
MM MACH 1 CREW MEMBER #2
McCain/Palin '08
Arsenal0328 (10:32:19 PM): mso gives me a raging hard on
Old July 15th, 2008, 07:10 AM   #4
N/A 4v Guru
Doc8224's Avatar
2003 Mach 1
He has a tuner.
Just plug in the gear that puts the speedo where it needs to be. you are looking at a differnent top end gear ratio on the 56 thats the issue. Do your calculations and put in the tuner what it needs even though its not what you have.
Project N/A 4V Under Way
yeah, sorry Turbo. I realized afterwards that I gayed up your thread. lol
Old July 15th, 2008, 08:12 AM   #5
Chris'schick's Avatar
Mtn. Bike
8.14@198.98MPH LOL
-97cobra
get ahold of a good dyno tuning shop and tell them what you got and Im sure they have came across a simular issue and could send you a correct tune for it.
Old July 15th, 2008, 10:42 AM   #6
ECUSVT31's Avatar
1999 SVT Cobra
14.36@98.46
Originally Posted by Doc8224 View Post
He has a tuner.
+1
Threads Similar to: Rear gear...speedo off!!!
Rear gear...speedo off!!! matted2thefloor Drivetrain 4 July 14th, 2008 08:21 PM
Speedo Gear.. 94StAnG5.0 Drivetrain 3 June 12th, 2008 12:55 PM
speedo gear product1620 96-98 14 May 8th, 2008 09:15 AM
Speedo Gear? MustangMatt96GT 96-98 1 July 7th, 2007 05:04 PM
3.73 and speedo gear untamed97stang Modular Mustangs 4 April 26th, 2007 11:31 AM
