Transmission leak!
Old July 25th, 2008, 12:27 AM   #1
2003 Ford Mach
Traveling at the speed of a photon
chris1 is on a distinguished road
Transmission leak!
I'll cut to the chase and specify where the leak is coming from.
It's splattered only on the right side of the cats and pipe. It's as if it popped internally when on the freeway. It hasn't dripped or leaked since then.
I was told either a seal (one by a converter) I do believe Its above the front sway bar. What are the common places on a trans for leaks to occur?
There is a pic below where my next door neighbor (Mercedez Mechanic) indicated the leak originated. I hardly use the car but seeing it in an immobilized state makes me hurt...lol
BTW the car still shifts properly and runs like normal.
[SIGPIC][/SIGPIC]
Under my Umbrella!
[I][COLOR=#ff0000]Studies show that 99.9% of the kids on MM ask the same questions over and over again about performance parts yet do nothing after the advice is given because they're still in Highschool and suffer from no money syndrome. [/COLOR][/I]
Old July 25th, 2008, 01:03 AM   #2
BLK01SS's Avatar
1/8 7.95@82.43
BLK01SS has a spectacular aura aboutBLK01SS has a spectacular aura about
Sounds like a front seal but I could be wrong.
Topless Mustang Club Founder
2000 Mustang Gt 5.4 SOLD
2001 Camaro SS
Originally Posted by rk_2000_Z/28 View Post
Black C6Z06=pure, hot, nasty, unprotected sex
Old July 25th, 2008, 01:07 AM   #3
N/A 4v Guru
Doc8224's Avatar
2003 Mach 1
Doc8224 is a jewel in the roughDoc8224 is a jewel in the roughDoc8224 is a jewel in the rough
Probably so.
Military Crew
U.S. Army Aviation
Apache's Lead The Way
Old July 25th, 2008, 01:08 AM   #4
2003 Ford Mach
If this happens to be a front seal leak, is that something to be concerned about? I'll wait for more input of those who may be more certain, but thank you.
[SIGPIC][/SIGPIC]
Under my Umbrella!
Old July 25th, 2008, 01:08 AM   #5
N/A 4v Guru
Doc8224's Avatar
2003 Mach 1
Just have to pull the tranny and replace it.
Military Crew
U.S. Army Aviation
Old July 25th, 2008, 01:10 AM   #6
2003 Ford Mach
Since I'll be pulling the tranny do you have a recommendation on a mod that'll work as a "bolt on" without any programming,tinkering etc.
[SIGPIC][/SIGPIC]
Under my Umbrella!
Old July 25th, 2008, 01:15 AM   #7
N/A 4v Guru
Doc8224's Avatar
2003 Mach 1
High stall converter and a shift kit. And a better tranny cooler
Military Crew
U.S. Army Aviation
Old July 25th, 2008, 01:19 AM   #8
2003 Ford Mach
Its an automatic. I think the transcooler should be good. How much cooler does it really keep the trans oil.
[SIGPIC][/SIGPIC]
Under my Umbrella!
Old July 25th, 2008, 01:23 AM   #9
N/A 4v Guru
Doc8224's Avatar
2003 Mach 1
Yea I know its an auto silly goose. thats why I said a high stall. the stock one is ok but the high stall converters make the fluid hotter and heat is the enemy in an auto. IMO the best cooler you can get for it is the best choice.
Military Crew
U.S. Army Aviation
Old July 25th, 2008, 11:24 AM   #10
2003 Ford Mach
Lol...
The TCI you recommended seems fine. Are they easy to install or is it rather difficult? BTW when the tranny will they be removing the exhaust and DS too? If so, than it's time to get a new toy.
[SIGPIC][/SIGPIC]
Under my Umbrella!
Old July 25th, 2008, 05:30 PM   #11
N/A 4v Guru
Doc8224's Avatar
2003 Mach 1
Originally Posted by chris1 View Post
Lol...
Yea,You you have to remove the mid pipe and DS.
Military Crew
U.S. Army Aviation
Old July 25th, 2008, 05:56 PM   #12
2003 Ford Mach
Sounds good.
[SIGPIC][/SIGPIC]
Under my Umbrella!
Threads Similar to: Transmission leak!
Transmission leak 99spaded 99-04 2 May 31st, 2008 01:56 AM
Transmission Leak Katen Classic Mustangs 15 January 29th, 2008 12:50 PM
Transmission Leak? 05MUSTANG4.0 V6 Mustangs 6 September 3rd, 2007 06:10 PM
transmission leak 69fastback Classic Mustangs 2 February 21st, 2007 10:39 PM
transmission fluid leak 87vert 5.0 Mustangs 6 January 8th, 2006 11:41 PM
