#22 |
1999 SVT Cobra
13.43
o yea? thatd be awesome man. if you do just send me a pm. prestige does charge a good bit, but its the only place i had thought of off teh top of my head
#24 |
1999 SVT Cobra
13.43
thanks doc. so about a little over 1500 for a supercharger kit. that doesnt sound too bad to me...
#25 |
99 Cobra Vert.
![]() iTrader: 1 reviews
Dont forget about relocating the alternator, and oil filter/cooler
-Sold- 1999 Mustang Cobra Convertible ![]() 2010 Harley Davidson Sportster "Forty Eight" XL 1200X |
#26 |
everything except pump and the manifold. I'll let you know if I find anything cheaper. The one on eBay has a TB plenum Blower Pulleys Heat exchanger injectors MAF and maybe more
99 Cobra 03 Cobra motor AFCO H/E Pulley JLT CAI BBK L/T off road H/steeda catback SCT MAF Tune 03 cobra pumps HVGC |
#27 |
1999 SVT Cobra
13.43
found this list..
Eaton Supercharger manifold wiring harness with fuel rail and injectors heat exchanger intercooler TB and plenum upper tensionor bracket lower pulley Intercooler piping, pump and tank alternator and bracket '03 cobra front timing cover 03 cobra harmonic balancer 03 cobra pump intlet tube and maf tune alternator and 2 brackets powersteering lines need to be relocated powersteering pulley
#28 |
1999 SVT Cobra
13.43
and this one...
1.) 2R3Z-6312-BAA Crank pulley /Harmonic Balancer 2.) 2R3Z-6C254-BC Supercharger Crank drive pulley 3.) 2R3Z-8678-BA Pulley w/mount Replaces stk alt. Pulley 4.) 2R3Z-8B603-BB Pulley bridge assembly for S.C. 5.) 1L2Z-8678-AB Idler pulley,timing cover LH side 6.) 2R3Z-6D080-BC Timing cover 7.) 2R3Z-6020-AA Timing cover gasket LH side 8.) 2R3Z-6020-BA Timing cover gasket middle 9.) 2R3Z-6020-CA Timing cover gasket RH side 10.) 2R3Z-10A313-AB Upper alternator bracket 11.) 2R3Z-10153-BA Lower alternator bracket 12.) 1U2Z-14S411-TA Electrical connector (alt. to harmness ) 13.) 2R3Z-6B209-AA Tensioner on timing cover 14.) 2R3Z-8260-AB Radiator hose 15.) 2R3Z-8A593-AB Radiator hose 16.) 2R3Z-8K576-AA Radiator hose 17.) 2R3Z-8286-AB Water cross over pipe 18.) F8ZZ-6881-AA Cobra oil cooler adapter Note: Use your stock gasket from your adapter or a leak will occur with a Cobra gasket! 19.) 2R3Z-6A642-AA Cobra Oil cooler 20. 2R3Z-9002-AA Cobra fuel tank 21.) 2R3Z-9H307-AB Cobra fuel pump 22.) 2R3Z-6F066-AA Eaton supercharger & inlet / T.B. 23.) 2R3Z-9424-BB Lower intake 24.) 2R3Z-6K775-?? Garrett factory intercooler 25.) 2R3Z-9H486-?? Intercooler to S.C. gasket 26.) 2R3Z-9A758-AA Cobra throttle cable 27.) 3U2Z-14S411-JUA IAT sensor connector 28.) 2R3Z-9H308A-?? Intercooler pipe to heat Exchanger 29.) 2R3Z-6K683A-?? “……………………………………..” 30.) 2R3Z-6K683B-?? “…………………………………….” 31.) 2R3Z-6K683C-?? “…………………………………….” 32.) 2R3Z-6K683D-?? “…………………………………….” 33.) 2R3Z-6K683E-?? “…………………………………….” 34.) 2R3Z-6K683F-?? “…………………………………….” 35.) 2R3Z-6K683G-?? “…………………………………….” 36.) 2R3Z-8501-?? Ford / Bosche water pump for intercooler 37.) 2R3Z-9L440-?? Factory heat exchanger 38.) 2R3Z-8A193-?? Heat exchanger mounting bracket 39.) 2R3Z-6C693-?? 2each bracket clamps 40.) 2R3Z-9H308C --?? Lower manifold to intercooler water adapter 41.) 2R3Z-6F089-?? EGR Valve 42.) 2R3Z- -?? EGR Tube to exhaust manifold 43.) 2R3Z- 8N500-?? Water pump intercooler bracket
Threads Similar to: 03/04 Cobra Supercharger
| 1996 cobra swap with 03 cobra heads and supercharger. | stan's96snake | 96-98 | 14 | October 30th, 2010 03:57 PM |
| Supercharger for 98 Cobra | Rakkasan21 | 96-98 | 47 | February 28th, 2008 12:17 PM |
| Cobra Supercharger | 2001Mustang Saleen | 99-04 | 12 | August 16th, 2007 01:07 PM |
| can a 03 cobra Supercharger be put on a 97 cobra? | 97Cobra | 96-98 | 2 | June 16th, 2006 08:51 PM |
