SRA back to IRS swap...spring issues..HELP!!!
Old August 4th, 2008, 06:59 PM   #1
matted2thefloor's Avatar
99 Cobra
13.77 @ 102
matted2thefloor is on a distinguished road
I posted this in the SVTP forums as well. I need to know what to do to take care of this issueBEFORE I get going on the swap. The donor car is coming from CT!!!
SRA to IRS swap...spring issues---help!!! - SVTPerformance
I need all the insight I can get...
Thanks
99 Cobra, T-56, Spec Stage 3, aluminum driveshaft, MGW shifter, shorties, X, FM Amer. Thunder, 3.73, SRA, JLT CAI, Tokico struts, adjustable UCA's/LCA's, H&R Rear Springs
Old August 4th, 2008, 07:08 PM   #2
HMUSN's Avatar
iTrader: 9 reviews
Originally Posted by matted2thefloor View Post
I finally found someone who wants to trade me my SRA for their IRS. His is a stock 03 IRS setup. Now heres where I get confused... My car is lowered using H&R 51650 rear springs. What spring will I have to have on the IRS to retian the same ride height? :??:
use the springs he is giving you with the irs. You'll need them anyway.
if he isn't giving you the springs just do the math.
Is his cars ride height stock? if so how high is it compared yours dropped?
once you find the difference you can pick springs up that evens it out.
Old August 4th, 2008, 07:34 PM   #3
99 Cobra
13.77 @ 102
The problem is that the lower control arms on my car now have the adjustable spring perch???
Old August 4th, 2008, 08:23 PM   #4
Priest of the Car Gods
ReverendDexter's Avatar
Clapped-out '90 GT 'vert
~5.5 seconds off TTOD :(
I fail to see how this is make-or-break for doing the IRS swap? You'll use whatever springs are with the IRS to get it in there, then get a set of rear springs with the proper drop, or do a coil-over conversion and use the adjustable perches to get your stance right.
I'm not seeing the complication?
O o
/¯/______________________
\_\
Buy my Bronco, special deal for MM folks
Old August 4th, 2008, 08:26 PM   #5
99 Cobra
13.77 @ 102
It's not about make-or-break...I just wanted to know what springs will give the ride height I have now so I can have him pick those up so we can put them in with everything out...to make it easier. And I wanted to make sure that I have all my ducks in a row before we get going on it.
Threads Similar to: SRA back to IRS swap...spring issues..HELP!!!
Irs ? Gear Swap stangage Modular Mustangs 10 May 27th, 2008 01:04 PM
IRS for SRA 99cobradroptop 99-04 0 January 28th, 2008 05:12 PM
Potential problems/issues with engine swap robz301 V6 Mustangs 22 December 26th, 2007 03:19 AM
IRS swap? energiesource 99-04 11 October 18th, 2007 04:45 AM
T-5 to T-56 swap and exhaust issues bgddy50 5.0 Mustangs 5 August 9th, 2006 01:50 AM
