need help asap!!!!
Old August 7th, 2008, 01:28 AM   #1
armymike63b's Avatar
2004 mustang mach 1
armymike63b is on a distinguished road
Send a message via AIM to armymike63b Send a message via Yahoo to armymike63b
need help asap!!!!
hey guys i'm confused as hell lol!!!!!.....i have no cats and i used mil's but the light was still on then i turned them off with my tuner and its still on what could the prob be......and does anyone know a step by step for putting the tune in ur car using the sct xcal 3
MM MACH 1 CREW
MILITARY CREW
Old August 7th, 2008, 01:34 AM   #2
Priest of the Car Gods
ReverendDexter's Avatar
Clapped-out '90 GT 'vert
~5.5 seconds off TTOD :(
have you got the codes it's throwing? That would be my first step.
O o
/¯/______________________
\_\
Buy my Bronco, special deal for MM folks
Old August 7th, 2008, 01:35 AM   #3
2004 mustang mach 1
i can 2morrow but when i do the tuner only gives the codes how do i find out what they mean
MM MACH 1 CREW
MILITARY CREW
Old August 7th, 2008, 01:37 AM   #4
01GTstang's Avatar
2001 MustangGT 2003 Cobra
GT-13.079 @ 104.69 Cobra-12.60 @ 111.11
01GTstang is on a distinguished road
Send a message via AIM to 01GTstang
Do you know anyone that works for ford? If you dont post up the codes real quick and i can find out for you by tomorrow mornin
2001 GT: For Sale, low 13s
2003 COBRA: 12.11@116
Old August 7th, 2008, 01:38 AM   #5
post 'em up here and/or google search.
Any code with a number under 1024 is a universal code, and is the same across all OBDII implementations, so you should be able to find those on google pretty easy. Any code over that is specific to make/model, and someone here should either know what they are, or be able to point you to the thread that has them all.
O o
\_\
Old August 7th, 2008, 01:42 AM   #6
2004 mustang mach 1
ok thanks guys....and i plan on takin the car to the track friday....are mustangs like other cars and don't run right when the cel is on
MM MACH 1 CREW
MILITARY CREW
Old August 7th, 2008, 01:47 AM   #7
N/A 4v Guru
Doc8224's Avatar
2003 Mach 1
Doc8224 is a jewel in the roughDoc8224 is a jewel in the roughDoc8224 is a jewel in the rough
did you reset the computer before you turned them off with the tuner? you need to clear the codes first. Then see if it comes back. try that
Military Crew
U.S. Army Aviation
Apache's Lead The Way
Old August 7th, 2008, 01:50 AM   #8
2004 mustang mach 1
i turned them off first then reset the computer is that backwards
MM MACH 1 CREW
MILITARY CREW
Old August 7th, 2008, 01:59 AM   #9
2004 mustang mach 1
and this may be a dumb ques. lol....but to reset the computer is it like the old cars where u just disconnect the the battery cuz my buddies rx8 is a wierd long process
MM MACH 1 CREW
MILITARY CREW
Old August 7th, 2008, 03:49 AM   #10
N/A 4v Guru
Doc8224's Avatar
2003 Mach 1
yea just unhook the battery for a little while then hook it back up and see if the light is off. If not use the tuner and read what code it is
Military Crew
U.S. Army Aviation
Threads Similar to: need help asap!!!!
I Need Help Asap 04mustang232 V6 Mustangs 15 May 25th, 2008 06:45 PM
need help asap!!!!!!! 88stangGT 5.0 Mustangs 20 May 19th, 2008 10:08 PM
Help Asap! Till 5.0 Mustangs 21 February 8th, 2008 04:16 PM
Help Asap MikeD05GT 96-98 10 December 27th, 2007 08:47 PM
help asap please WeCircleTheProblem V6 Mustangs 14 August 16th, 2007 07:21 PM
