04 mustang cobra
04 cobra belt problems
i just installed a 2.76 s.c. pulley and a 90mm aux. idler pulley kit on my 04 cobra. my problem is i cant get the belt on now..its tight...is this normal?? im sure all the other pulleys are stock. yet i have the gatorback #4800745...any tricks or sugestions would be great.
2003 Cobra
that belt should fit and maybe a half inch smaller one with that setup. are you sure you have it on the alt. pulley all the way and all other pulleys.
Billy Weston
yeah its a bitch to put on from the top. if you put it on all the other grooved pulleys then slide it over the idler in between the alt and crank, then slide it over the idler in between the new idler and the alternator it goes on much easier. having two people also helps.
![]() TT Build in progress....... Need work done to your car for a great price in Hampton Roads? Shoot me a PM. |
#4 | |
2003 Cobra
04 mustang cobra
i had it on all the pulleys all the way.checked that like 3 time...i put on the original belt (not sure if its factory) and it fits fine...it was about 1/2"-3/4" of an inch larger...my tensioner is almost all the way tight, only has about 1/8"-3/16" before its all way tight...if that makes any sense to anyone, i just hope it dont slip
You can also knock the stop tab off the tensioner to give yourself some more travel when you are trying to squeeze a tight belt on.
Billy Weston
i am running my stock belt.....
04 mustang cobra
i had thought about cutting off part of the stop on the tensioner...the belt that i got with pulley is too small i think..with it off of one idler pulley the belt stretches only half way accross the pulley..there is no way in my eyes it will stretch over...i dunno
#9 | |
Threads Similar to: 04 cobra belt problems
| Belt Problems | NYMustang21 | V6 Mustangs | 1 | July 13th, 2008 02:02 PM |
| what size belt to use for 03 cobra | etony89 | 4V / SVT | 4 | June 12th, 2008 07:38 AM |
| Belt Size for Cobra Underdrive Pullies | sctravis77 | 96-98 | 0 | February 4th, 2008 08:15 PM |
| Rear side seat belt problems | Archy88 | General Tech | 1 | October 9th, 2007 04:09 AM |
| me with a slipping belt vs 03 cobra | sonicblue | Videos | 9 | September 5th, 2007 01:22 PM |
