A little MAF swap help?
Recently I purchased for quite a deal off eBay a ProFlow 90mm/87mm MAF which is for a 96 Cobra (stamped on the MAF) and calibrated for 24# injectors. The only problem here is the car barely runs with the unit installed.
The car has to be babied at 1500 rpms to prevent it from even stalling, and then it barely would start. Swapped back to stock - works fine. I have a SCT Livewire, but I'm not sure I can do a whole lot. I don't really need a larger MAF yet, but I'd like to use it. (Damn if it's not just pretty looking alone.) Any ideas or suggestions on what simple fix I'm missing because I love missing the obvious answer? Thanks.
Slowly but surely creeping into the 12's on a stock N/A block...
KB'd GT
Proflow? Who makes them? My guess is its a crappy maf and needs a tune to work correctly. Using mafs cal'd for injectors is the very old way of doing things. Now its all done in the tune.
I don't think this brand has been around in quite a long time probably explaining why this isn't working, it's probably from 1998.
Threads Similar to: A little MAF swap help?
| Which one is easier??a rear end swap or engine swap? | Bies08 | V6 Mustangs | 42 | May 11th, 2010 04:33 PM |
| 1995 351 to swap or not to swap.& how to? | Jeffery9508 | 94-95 | 9 | August 3rd, 2008 08:00 AM |
| SVO - Vane to MAF Swap | sudo95 | 2.3 Mustangs | 6 | January 24th, 2008 05:48 PM |
| maf electronics swap | usmcsawgunner | 5.0 Mustangs | 1 | December 24th, 2007 01:18 PM |
| Can't decide, engine swap or PI swap? A few questions... | k3vin | 96-98 | 24 | September 5th, 2007 06:48 PM |
