exhaust leak on 97 4v
Old August 24th, 2008, 10:53 PM   #1
beheivjer's Avatar
beheivjer is on a distinguished road
i keep getting a catalyst below efficency code on my 97, im thinking i have an exhaust leak can you change the manifold gaskets without pulling them? just trying to figure out which way to go its our only car right now and need it so the wife can go to the rest of her LPN classes.
1969 Early Bronco 3.5" lift 37" swampers
1969 Early Bronco 2" lift half cab
1979 2.3t Cobra
1997 Black Cobra
http://www.cardomain.com/ride/680999
http://www.myspace.com/beheivjer
Old August 24th, 2008, 11:10 PM   #2
N/A 4v Guru
Doc8224's Avatar
2003 Mach 1
Doc8224 is a jewel in the roughDoc8224 is a jewel in the roughDoc8224 is a jewel in the rough
its a 97, if you still have the stock mid pipe your cats may well be going bad. check the tailpipes for a rotten egg smell.
Military Crew
U.S. Army Aviation
Apache's Lead The Way
Old August 24th, 2008, 11:52 PM   #3
beheivjer's Avatar
nope i have a bbk o/r xpipe it is a leak at the manifold i think.
1979 2.3t Cobra
1997 Black Cobra
Old August 25th, 2008, 01:17 AM   #4
N/A 4v Guru
Doc8224's Avatar
2003 Mach 1
if you never put MIL's on it or had a tune to turn off the rear 02's then thats why it is throwing a code.
Military Crew
U.S. Army Aviation
Old August 25th, 2008, 01:39 AM   #5
beheivjer's Avatar
has mils on it right now, but thats not what im asking, it has an exhaust leak, i am wanting to know if you can unbolt enough to get new gaskets in or do they have to come all the way out. This isnt my first stang by the way its just my first 4v. Just had manifold questions that i need answered
1979 2.3t Cobra
1997 Black Cobra
Old August 25th, 2008, 01:50 AM   #6
N/A 4v Guru
Doc8224's Avatar
2003 Mach 1
no they have to unbolt all the way. Ford replacement gaskets aren't the drop in kind but the ones from the parts store will probably be the drop on kind. I wasn't trying to say you didn't what you are talking about, I was just saying what the catalyst code usualy comes from. You shouldn't be getting that code with MIL's. Just sayin man.
Military Crew
U.S. Army Aviation
Old August 25th, 2008, 11:01 AM   #7
Mustang RacR94's Avatar
03 mach 1
13.2@109
Mustang RacR94 will become famous soon enoughMustang RacR94 will become famous soon enough
Send a message via AIM to Mustang RacR94
the manifold/headers has to come off all the way, but you shouldnt be getting that code either way with the MIL eliminators, ive had 3 different MIL eliminators and all them went bad, all I can say is unplug the battery for 10 minutes and recconect it, if the code comes back up after a little, then the eliminators arent working, a exhaust leak before the front 02 sensor should throw that code anyway I wouldnt think, that usually comes up when the 02 sensor detecs that two much of whatever is going thru the rear one compared to the front. with MIL eliminators if there working you shouldnt be getting that code anyway. I know my prochamber leaks all the time right where it meets up with the drivers side header, so I dont know if you checked it out but I would before you go buy a gasket for the header.
2003 Mach 1, 5 speed
U.S. Army - 11B
"And on the 8th day god created the infantry and all hell stood at attention"
Old August 25th, 2008, 11:11 PM   #8
beheivjer's Avatar
Symptoms
You will likely not notice any drivability problems, although there may be symptoms.
Causes
A code P0420 may mean that one or more of the following has happened:
* Leaded fuel was used where unleaded was called for
* An oxygen sensor is not reading (functioning) properly
* The engine coolant temperature sensor is not working properly
* Damaged or leaking exhaust manifold / catalytic converter / exhaust pipe
* Retarded spark timing
* The oxygen sensors in front and behind the converter are reporting too similar of readings
Possible Solutions
Some suggested steps for troubleshooting a P0420 code include:
* Check for exhaust leaks at the manifold, pipes, catalytic converter. Repair as required.
* Use a scope to diagnose the oxygen sensor operation (Tip: The oxygen sensor in front of the catalytic converter normally has a fluctuating waveform. The waveform of the sensor behind the converter should be more steady).
* Inspect the downstream heated oxygen sensor (HO2), replace if necessary
* Replace the catalytic converter
1979 2.3t Cobra
1997 Black Cobra
Old August 25th, 2008, 11:12 PM   #9
beheivjer's Avatar
it only happens on one side and if i switch the mils to oppisite sides it doesnt follow them
1979 2.3t Cobra
1997 Black Cobra
Old August 26th, 2008, 12:04 AM   #10
1998 Cobra
13.24@105.66
def exhaust leak. Mine throws the p0430 code (the other side), and it has a slick exhaust leak 'tick'
isn't obd2 awesome and finicy! lol
weeee foooord!
Old August 26th, 2008, 09:48 PM   #11
beheivjer's Avatar
i love the exhaust tick that everyone points out along with my throwout clicking all the flippin time
1979 2.3t Cobra
1997 Black Cobra
Threads Similar to: exhaust leak on 97 4v
Exhaust leak? hardhitter 99-04 6 April 6th, 2008 05:08 AM
Exhaust leak? Drtbkercr5 General Tech 6 March 17th, 2008 11:45 PM
Exhaust Leak? Gunny 2005 - 2010 8 December 3rd, 2007 12:35 PM
exhaust leak JASonic General Tech 7 October 14th, 2007 11:17 PM
exhaust leak or something else? mikethetigerrr V6 Mustangs 9 July 6th, 2007 08:52 PM
