spark plugs and wires
how do you change the spark plugs and wires on a 04 mach 1.....and what kinda plugs and wires should i go with
MM MACH 1 CREW MILITARY CREW |
just pull the wires off the coil/plug and match it up to the new one that's the same length.
I love ngk plugs.. i've ran them in my camaro, 240sx.. everything. 1.50 copper cheapo ngk's.
weeee foooord!
Priest of the Car Gods
agreed, NGKs ftw.
I've seen several dyno comparisons of NGKs versus a bunch of other plugs, including fancy-pants multi-electrode plugs. All the plugs will be within 1 or 2 hp, and all 3-5 hp down on the stock NGKs. Whatever you do, do NOT get Bosch mult-electrode plugs. Waste of money, and the electrodes are prone to breaking off. For wires, I'm a fan of Sumitomo wires (they're the stock wires on Toyotas, and consistently go for over 150k miles), but I've never seen 'em available as an aftermarket wire for anything else. So I usually go with NGK or Denso wires. sparkplugs.com should have everything you need.
2003 Ford Mach
Traveling at the speed of a photon
I've used Bosch Platinums in the Gt with no problem at all. I'm currently running the Iridium plugs in the mach and they seem to be working fine. I currently have a friend who gives me the plugs for about a dollar
[SIGPIC][/SIGPIC] Under my Umbrella! [I][COLOR=#ff0000]Studies show that 99.9% of the kids on MM ask the same questions over and over again about performance parts yet do nothing after the advice is given because they're still in Highschool and suffer from no money syndrome. [/COLOR][/I] |
You don't have spark plug wires on your 04 Mach.
DAMN. Beat me to it..
BTW armymike63b, have you even opened the hood on your car yet? |
yes i have opened my hood just the mach is so much diff......what do i have if i dont have wires
#8 | |
You have coils directly on each spark plug. Coil On Plug. COP. So 8 coils, 8 plugs, and electrical wires running to each COP. All you can change are the coils and plugs, but if there is nothing wrong with the coil, there's no need to change it. And most people will tell you that the stock coil is the best set-up. No point in going aftermarket really. |
Threads Similar to: spark plugs and wires
| Spark plugs and wires | BDaily | V6 Mustangs | 4 | June 8th, 2008 08:19 PM |
| spark plugs/ wires help | stang300a | V6 Mustangs | 35 | February 16th, 2008 05:09 PM |
| Spark plugs and wires | 96GtGoodz | 96-98 | 8 | November 7th, 2007 11:57 AM |
| spark plugs and wires | machy | V6 Mustangs | 3 | July 31st, 2006 10:16 AM |
| 99 Mustang GT (Spark plugs, wires & Coil pack) | joey0976 | 99-04 | 17 | July 18th, 2006 10:13 PM |
