#41 |
i know a guy who just put on a t-trim, and messed up a head so he had the motor rebuilt... i think he's looking at 4k total after forged rods and low compression pistons... you will spend WAY more getting 400 hp out of a n/a motor, and he's gonna be closer to 500 when it's all said and done and maybe another 500 into it... in short, do NOT buy udps... broken oil pump theory or not, they'll have to come off for the s/c kit... cai is a waste too... take the money from those two mods and put it towards a good tb, it will do nothing right now, but once you s/c it will help... also long tubes and or/x or or/h will help a lot too
#42 |
yeah but i'm not sure if i will ever sc it
MM MACH 1 CREW MILITARY CREW |
#43 |
MM's Orangest
2004 Mach 1 Mustang
Buy the TB if and when you get a S/C kit. I really don't think the UDPs are worth the money. There are plenty more mods you can do. Save up and get long tubes and a shorty midpipe or gears (+install).
![]() 360HP / 345TQ N/A |
#44 |
Blown 03 GT
Well if you want power its your best route, From what Ive read guys are claimin an increase in MPG with normal driving. And if you go the centri way your only in boost when you get on it.
#45 | |
Saving up for another one
its the same way with roots and twinscrew blown cars. im not sure about turbo cars. |
#46 |
Blown 03 GT
I thought roots and twin screw produce boost all the time?
#47 |
according to the boost gauges, they dont. |
#48 |
so what long tubes and midpipe
#49 |
MM's Orangest
2004 Mach 1 Mustang
Roots/Twin Screw make power throughout the RPM band that's just how they work. Centris have a powerband much like a turbo except that they are belt driven so they only make substantial power above say 3000-3500.
As for long tubes and a midpipe that is up to you. Make sure that when you are looking for them that you look for the following things: 1. LTs built for a 4v motor. 2. Make sure that the midpipe you buy is a SHORTY midpipe. The stock midpipe or the aftermarket midpipe you bought for the stock headers will be too long and won't fit with long tubes. 3. Shorty midpipe options: X/H/Prochamber If you buy a certain long tube header you are probably better off buying the same manufacturer's midpipe. Lethal Performance has a good selection of long tubes and midpipes for Mach 1s.
#50 |
N/A 4v Guru
2003 Mach 1
You will have to at least do everthing from the heads up,have a great cam selection, manifold work or aftermarket manifold, ALL the bolt ons and a great tune. That might give you close to 400 N/A. I am doing a fully built and balanced motor, head work, cams, all the bolt ons and a good tune to get 400 N/A. Its not easy man. You can not do it N/A without at the very least doing everything from the heads up
![]() Military Crew U.S. Army Aviation Apache's Lead The Way |
#51 |
Correct. Same for turbo cars. Any boosted car is not always in boost untill you give it enough gas input to create the boost.
#52 |
I have had Steedas on my Mach for 2yrs no problems.
AutoMachtic |
#53 | |
Moderator
#54 |
F-150 FX4
I would do full bolton's, aluminum driveshaft, and some big gears.... Guy's on Mach1registry are running mid 11's wth bolt on mach1's because they put big gears, tires, and slight suspension work.
Your MPG will go down on the highway with big gears but increase in the city because it makes it easier for the engine to get moving |
#55 |
[QUOTE=Reloaded;1388622]Correct. Same for turbo cars. Any boosted car is not always in boost untill you give it enough gas input and a load is put on the engine. QUOTE]
fix't
#56 |
Still thinking about nos, its relatively inexpensive and if done right will be just fine on the stock motor.
Because I'm the best there is at what I do, and what I do best isn't very nice. |
#57 |
if you want to spend less money nd more HP UDP are not the way to go. you get maybe 5 Hp for like 150$. save up for a blower.. just my .02
#58 |
futuremachracer. alot of shit happened to my engine a week after i put UDP's in my babys still in the shop because of it getting intake valves machined down.
99 SVT cobra |
#59 |
2003 Ford Mach
Traveling at the speed of a photon
Oil pump failure i suppose? You rev it alot don't you.
[SIGPIC][/SIGPIC] Under my Umbrella! [I][COLOR=#ff0000]Studies show that 99.9% of the kids on MM ask the same questions over and over again about performance parts yet do nothing after the advice is given because they're still in Highschool and suffer from no money syndrome. [/COLOR][/I] |
#60 |
Honeybadger is Crazy
With full botons and 175 shot I put down almost 500 at the tire. I've run in the low low 11's in the 1/4 mi. Then again I have a big gear, slicks, and moderate suspension work.
RIP Travis Bilings 5/6/1982-7/5/2011 Be polite. Be professional. But have a plan to kill everyone you meet. |
