IRS to Solid
LinkBack (1) Thread Tools
Old August 27th, 2008, 09:55 PM   1 links from elsewhere to this Post. Click to view. #1
fox87stang's Avatar
99 Cobra
UNK
fox87stang is on a distinguished road
Send a message via AIM to fox87stang
IRS to Solid
I need to know every single part that is neede to convert my irs to a solid rear axle, either stock gt or aftermarket axle. Also, for anyone who knows, How long does this process take, is it a project that a mildly knowledgeable person can do, and an estimate on cost?
Also, How will it hold up to a mild bolt-on cobra with 4.10 and DRs? Will i be replacing shit on it to?
MM Cobra Club #20
1999 Cobra - Custom black/silver paint, 18" chrome Saleen wheels, BBK CAI, H-pipe, bullet mufflers, FRPP 4.10's and 305 Nitto DR's
Old August 28th, 2008, 02:02 AM   #2
'97'Cobra's Avatar
1997 Mustang Cobra
8.65@84mph
'97'Cobra has a spectacular aura about'97'Cobra has a spectacular aura about'97'Cobra has a spectacular aura about
Dont know about the hole swap thing but mine has held up so far and i launch it hard, all the time. i got gears and springs but thats it. What part of tyler you from i grew up in whitehouse
i usually wave first, but if the guy is sexy and i'm drunk, i might lift up my shirt and flash him as well.
MM Cobra Club Member #61
Old August 28th, 2008, 08:45 AM   #3
04 mustang cobra
killerSVTcobra is on a distinguished road
you will need upper/lower control arms, rear springs/shocks, cobra brake bracket kit. it is better to use a 99-04 gt housing because they are 3/4 in longer on each side. if you use aftermarket control arms you dont need the quad shocks. i didnt put the abs sensors back in...and i have no brake light on. i bought all new stuff and i have about 2000-2100 into the swap. i used FMS axle housing and internals(31 spline) and steeda suspension components then cheap monroe rear shocks. that should be plenty stong unless you are making gobbs of power then you might want to do a 9in.
If you cant hear the whine, then your behind
Mods: solid axle with 3.73's, MGW shifter, bassani cat-back, afco heat exchanger, k&n fipk, C&L intake tube, accufab throttle body with s.c. inlet, 2.76 upper pulley, 90 mm aux idler pulley, sct tuner
Old August 28th, 2008, 12:56 PM   #4
fox87stang's Avatar
99 Cobra
UNK
alright thanks guys...im from near gilmer in a community called harmony/latch
MM Cobra Club #20
LinkBack to this Thread: http://www.moddedmustangs.com/forums/4v-svt/86523-irs-solid.html
IRS to Solid This thread Refback August 28th, 2008 09:18 AM
Threads Similar to: IRS to Solid
Wanna trade your IRS for my Mach 1 solid axle? rzuvich 4V / SVT 3 May 14th, 2007 01:03 PM
Wanna trade your IRS for my Mach 1 solid axle? rzuvich General Tech 5 April 13th, 2007 10:01 AM
Wanna trade your IRS for my Mach 1 solid axle? rzuvich 99-04 10 April 10th, 2007 09:40 PM
Wanna trade your IRS for my Mach 1 solid axle? rzuvich Drag 1 April 9th, 2007 10:08 PM
Wanna trade your IRS for my Mach 1 solid axle? rzuvich Racer's Corner 0 April 9th, 2007 09:37 PM
