Discussing car breaking uptop in the 4V / SVT Forum. its been a week since i purchased 03 cobra it was stock except for k&...
Old September 1st, 2008, 02:17 AM   #1
car breaking uptop
its been a week since i purchased 03 cobra it was stock except for k&n intake, added bassani cat-back, 2-80 pulley, diablo predator tuner, everytime i gu it and gets to 5k rpm's it starts to like buck, hesitates, could it be the plugs, any help appreciate it
Old September 1st, 2008, 03:31 AM   #2
N/A 4v Guru
Doc8224's Avatar
2003 Mach 1
could be a couple things, plugs, tune, etc. need a little more info on what exactly its doin. who did the tune?
Gone To Basic Training
Old September 1st, 2008, 04:45 AM   #3
thundersports auto here in south florida, he said it could be the plugs, i think thats a possibility since all the new added parts and hp they prob need to be regapped i just dont know wht gap to run, even though b4 doing the mods the car had a slight miss, oh and now if i brake hard sometimes the car will shut off
Old September 1st, 2008, 04:48 AM   #4
when i go about 46ish to 5k rpm's the car breaks up and then kinda catches on but i can notice there isn't much power after that maybe its the Heaton since the car has 78k miles n the clock
Old September 1st, 2008, 01:06 PM   #5
N/A 4v Guru
Doc8224's Avatar
2003 Mach 1
I would change the fuel filter and see if that helps. then if it still does it then change the plugs out.
Old September 1st, 2008, 01:26 PM   #6
1998 SVT Cobra
you did all those mods when you knew the car had a miss?
*The Sacred Chao says "MU"*
Real racers turn corners... both ways... on the same track.
MM Corner Carvers Crew, member #2
Old September 1st, 2008, 01:32 PM   #7
Mod mach's Avatar
I had the same problem when I would let off the gas at over 30mph it would go off on me,I reset the pcm and hasn't done it since.I'm not sure about the 5k thing it might be the tune but if it has 78k and yopu just got it I would change the plugs first+fuel filter.
Old September 1st, 2008, 06:15 PM   #8
the motorcraft plugs were gap'd at 47
Old September 1st, 2008, 09:46 PM   #9
Black02GT's Avatar
03 Mach 1--~--1 of 2513
8.9 1/8 mile time
why dont you datalog the tune and let the guy check it out. maybe its leaning out? or something gay like that
regardless datalog might help you find the problem area
Originally Posted by HMUSN it's like racing a mach 1 .. not untouchable but still gonna lose plain and simple no matter how you roll the dice.
SaleenWolf720: need horsepower?? no, you just need bald tires, then you'll really feel the power
Old September 1st, 2008, 09:51 PM   #10
91 mustang lx coupe
way too slow
true true... almost sounds like a vacuum leak to me though... no lean codes? try a koer self test, see if it pulls any codes... check your 02 readings while spraying carb cleaner around the intake... and try the datalogging thing, see if it fattens up or leans out.. that will point you in the right direction.. any fuel issue will lean up and a spark issue, it'll run rich up top...
Old September 2nd, 2008, 09:30 AM   #11
04 mustang cobra
maybe you need to get a colder plug with the proper gap since you are making more boost, fuel filter or bad gas
If you cant hear the whine, then your behind
Mods: solid axle with 3.73's, MGW shifter, bassani cat-back, afco heat exchanger, k&n fipk, C&L intake tube, accufab throttle body with s.c. inlet, 2.76 upper pulley, 90 mm aux idler pulley, sct tuner
Threads Similar to: car breaking uptop
Breaking Out! (car show) jdansby1 Pictures 37 May 29th, 2008 05:57 PM
Breaking Out! (car show) jdansby1 The Clubhouse 0 March 2nd, 2008 07:44 PM
Alls I Want For Christmas Is To Run My Car Without Breaking! sonicblue The Clubhouse 17 December 20th, 2007 07:33 PM
Breaking News! (Car Show) WAVEBYE Modular Mustangs 2 October 7th, 2006 11:54 AM
Hi Guys I Want To Keep My Car Colder Without Breaking Bank jagstang96 96-98 6 October 6th, 2006 11:59 PM
