accufab t/b and plenum
Old September 2nd, 2008, 06:50 AM   #1
03snakeminated is on a distinguished road
i am in the process of buying a ported eaton and was thinking about getting the accufab t/b and plenum is it worth it in a comparison to a ported t/b and plenum would i see more performance on the accufab one?
Old September 2nd, 2008, 08:35 AM   #2
04 mustang cobra
killerSVTcobra is on a distinguished road
the stock t.b. and s.c inlet flow right around 1000-1100 cfm and the accufab unit flows just over 1600 cfm. i noticed a big differance swapping to the accufab, but they are expensive
If you cant hear the whine, then your behind
Mods: solid axle with 3.73's, MGW shifter, bassani cat-back, afco heat exchanger, k&n fipk, C&L intake tube, accufab throttle body with s.c. inlet, 2.76 upper pulley, 90 mm aux idler pulley, sct tuner
Old September 2nd, 2008, 09:56 AM   #3
N/A 4v Guru
Doc8224's Avatar
2003 Mach 1
Doc8224 is a jewel in the roughDoc8224 is a jewel in the roughDoc8224 is a jewel in the rough
I would get the accufab big mouth TB and just P&P the stock inlet
Military Crew
U.S. Army Aviation
Apache's Lead The Way
Old September 3rd, 2008, 04:55 AM   #4
jumperjack's Avatar
jumperjack is on a distinguished road
I have a polished Accufab plenum that is P&P shoot me a p.m. if you are interested.
Old September 5th, 2008, 02:16 AM   #5
2004 Mustang Mach 1
14.02@101.27 pretune
RoBob31 is on a distinguished road
Does any one know where i can get a good throttle body for a 04 mach 1 thats under $300. I dont care if its used or not.
Old September 5th, 2008, 03:59 AM   #6
N/A 4v Guru
Doc8224's Avatar
2003 Mach 1
Ebay. You will definatly find one for that price. they are the same on the 99-01 cobra's too so you can widen your search criteria
Military Crew
U.S. Army Aviation
Old September 5th, 2008, 07:01 PM   #7
2003 Cobra
1StockGT is on a distinguished road
Send a message via AIM to 1StockGT
I got an awesome deal locally for a used Accufab for $150, but it says Kenne Bell on it. The only problem I've had with mine for the month or so it's been on is the cruise control doesn't work all that great. I would also recommend a single blade t/b over a ported stock one. I noticed a pretty big difference also.
Threads Similar to: accufab t/b and plenum
Where can I get the cheapest Accufab T/B and Plenum? andres0286 99-04 7 March 24th, 2008 11:33 PM
I got my accufab 75mm tb and plenum jrfan4life 99-04 1 February 28th, 2008 07:27 PM
Accufab 75mm Tb And Plenum 2000stangGT 99-04 8 September 17th, 2006 08:43 PM
