Replacement of High Flow Cats.
Old September 5th, 2008, 09:55 AM   #1
2003 Ford Mach
Traveling at the speed of a photon
chris1 is on a distinguished road
Service engine light came on with code P0430. I understand that this is a catalytic converter problem, exhaust leak, or an o2 sensor about to give out.
Anyways, I have a bassani X pipe with "High Flow Cats" and I was wondering if they can be replaced with different Hi-performance cat (magnaflow). If so, which one would be highly recommended.
[SIGPIC][/SIGPIC]
Under my Umbrella!
[I][COLOR=#ff0000]Studies show that 99.9% of the kids on MM ask the same questions over and over again about performance parts yet do nothing after the advice is given because they're still in Highschool and suffer from no money syndrome. [/COLOR][/I]
Old September 5th, 2008, 10:29 AM   #2
Mustang RacR94's Avatar
99 cobra
N/A
Mustang RacR94 will become famous soon enoughMustang RacR94 will become famous soon enough
Send a message via AIM to Mustang RacR94
jegs.com sells a bunch of replacment hi-flow cats, id def go with magnaflow, which they sell
99 Cobra
03 Cobra motor
AFCO H/E
Pulley
JLT CAI
BBK L/T off road H/steeda catback
SCT MAF
Tune
03 cobra pumps
HVGC
Old September 5th, 2008, 11:25 AM   #3
2003 Ford Mach
Do they come in different sizes or does one size fit all? Will it be a direct bolt-on without and modification or major adjustment>
[SIGPIC][/SIGPIC]
Under my Umbrella!
Old September 5th, 2008, 11:45 AM   #4
04 mustang cobra
killerSVTcobra is on a distinguished road
you might be getting an engine code because aftermarket cats arent as efficent as the factory ones....i work at a chevy dealership and see this problem alot
If you cant hear the whine, then your behind
Mods: solid axle with 3.73's, MGW shifter, bassani cat-back, afco heat exchanger, k&n fipk, C&L intake tube, accufab throttle body with s.c. inlet, 2.76 upper pulley, 90 mm aux idler pulley, sct tuner
Old September 5th, 2008, 11:55 AM   #5
2003 Ford Mach
The code was read and removed at a Ford Dealership. The "Service Engine" light hasn't been back in about 2 days.
[SIGPIC][/SIGPIC]
Under my Umbrella!
Old September 5th, 2008, 11:58 AM   #6
Priest of the Car Gods
ReverendDexter's Avatar
Clapped-out '90 GT 'vert
~5.5 seconds off TTOD :(
Unless the law changed and you can find one with a CARB number, high-flow cats aren't smog-legal anyway.
O o
/¯/______________________
\_\
Old September 5th, 2008, 06:07 PM   #7
99 cobra
N/A
jegs sells 50 state legal high flow cats, and try getting some MIL eliminators they can make the code go away
99 Cobra
03 Cobra motor
AFCO H/E
Pulley
JLT CAI
SCT MAF
Tune
03 cobra pumps
HVGC
Threads Similar to: Replacement of High Flow Cats.
High Flow CATS dgt_mustang V6 Mustangs 14 April 26th, 2008 12:09 PM
h-pipe w/ high flow cats BWAL 5.0 Mustangs 4 April 17th, 2008 03:11 AM
Help?! (High Flow Cats and H-Pipe) Samuel1881 V6 Mustangs 6 April 2nd, 2008 05:37 PM
Anyone weld high flow cats? Hawaiianbro 99-04 5 January 1st, 2008 06:34 PM
High flow cats.........how do they sound? militant54 General Tech 4 September 19th, 2007 11:48 AM
