Question regarding hesitation (Tune info) Eaton swap @WOT
Old September 12th, 2008, 03:24 PM   #1
Reloaded's Avatar
2004 Mach 1
Reloaded is just really niceReloaded is just really niceReloaded is just really niceReloaded is just really niceReloaded is just really nice
Send a message via AIM to Reloaded
The car is tuned using Sniper, and I just mailed the most recent datalog off to the tuner to see if he can figure this out, but I thought I would ask here too, in case it's not the tune. Under WOT, I notice hesitation from time to time through the gear. Maybe 3-4 times it'll almost seem to stop accelerating for a moment. I have the data log in Excel format since I'm sure most don't have Sniper to read it with. But I guess that I can't post it here. I can e-mail it though if someone wants to look at it. A/F is 11.6, almost steady, but never goes above 12.0. Stock upper and lower pullies, stock intake, Sniper MAF, stock Cobra injectors, stock Cobra tank and pumps. Any other info you need, let me know and I'll post what I know. Thanks!
MM Cobra Club #42
417 HP & 413 TQ (Old #s)
422 HP & 453 TQ (New #s)
492 HP & 502 TQ (with Posi and 2lb lower)
Originally Posted by BuRnIn_YoUrS View Post
Dude...it takes alot to make me gag...
Old September 12th, 2008, 03:34 PM   #2
WilltheThrill's Avatar
Saving up for another one
WilltheThrill has a spectacular aura aboutWilltheThrill has a spectacular aura aboutWilltheThrill has a spectacular aura about
belt slip maybe?
Yes those are cobra R replica mustang wheels on my 300zx
03 Cobra- gone but not forgotten
90 Nissan 300zx
00' Yamaha YZF 600
Originally Posted by '97'Cobra View Post
I was too drunk even tell which hole i was gettin after.
Old September 12th, 2008, 03:42 PM   #3
Reloaded's Avatar
2004 Mach 1
Originally Posted by WilltheThrill View Post
belt slip maybe?
That'd be funny since it's all the stock stuff. But when I had it dyno'd way back when on the break-in tune, boost stayed at a constant 8.16psi the whole way through. But for the hell of it, I'll keep an eye on the boost gauge next run.
Here's a bit of extra info too, that I find odd. It doesn't always hesitate. I was noticing it more during the day. But then it did it last night, and it was nice and cool out, so the theory of heat is out the window. My IAT temps were super low. Also, it did it all 3 times I went WOT in 3rd, but 4th seemed nice and smooth (only went from about 2500-4500 or so), and it also hesitated the one time I went WOT in 2nd. So I have no clue.
MM Cobra Club #42
Old September 12th, 2008, 03:45 PM   #4
well i guess the belt could start slipping at any time. go in there and make sure theres no kind of film or residue on the belt or where the belt contacts the pulley.
i wonder if you need a new fuel filter like me?
90 Nissan 300zx
00' Yamaha YZF 600
Old September 12th, 2008, 03:57 PM   #5
Reloaded's Avatar
2004 Mach 1
Belt is about 2000 miles old, but I'll take a look at it this evening.
Filter was changed about 3000 miles ago. Fuel injection flush was done about 10,000 miles ago. But the injectors/tank/pumps are used, so perhaps the tank was dirty, or injectors are dirty. Changing the filter and doing a flush are easy. Maybe I'll try it just for the hell of it if I can't figure something else out.
MM Cobra Club #42
Old September 12th, 2008, 04:01 PM   #6
2003 Ford Mach
Traveling at the speed of a photon
chris1 is on a distinguished road
I'm sorry to throw this thread off topic reloaded, but what are you putting down in rwhp on a dyno?
[SIGPIC][/SIGPIC]
Under my Umbrella!
[I][COLOR=#ff0000]Studies show that 99.9% of the kids on MM ask the same questions over and over again about performance parts yet do nothing after the advice is given because they're still in Highschool and suffer from no money syndrome. [/COLOR][/I]
Old September 12th, 2008, 04:15 PM   #7
Reloaded's Avatar
2004 Mach 1
Well the dyno was terrible. The break-in tune kept pulling timing and the car was running like crap, but it put down 378. Once I get the tune dialed in correctly, should be around 400ish. It's running MUCH stronger than when I had it dynoed. I'll be going back again once it's fixed.
BTW, it was running so bad that they did two pulls, and said it was free. Haha. He told me to come back when "I would put down some real numbers". The graph was all over the place.
MM Cobra Club #42
Old September 12th, 2008, 05:43 PM   #8
Trick Tuners's Avatar
KB'd GT
Does it hesitate on shift, on tip in, or when already at WOT? Email the log to joe@tricktuners.com with a link to this thread and i'll look it over and maybe post up some pictures of the data graphs.
Old September 12th, 2008, 06:14 PM   #9
Reloaded's Avatar
2004 Mach 1
I am cruising at about 2500 RPMs, then go WOT and through whatever gear I'm in it hesitates. Does not seem to hesitate between shifts. Only when I'm already going WOT through a gear, or making a pull basically. E-mailed. Thanks!
MM Cobra Club #42
Old September 12th, 2008, 08:40 PM   #10
KB'd GT
If the problem is only on tip in, the fuel system needs to be tuned better. Other than the pressure drop on the hit, everything looks ok. For some reason my picture didn't upload correctly. The pressure drops to around 28 psi on the initial hit and it probably runs lean.
Old September 12th, 2008, 09:07 PM   #11
Reloaded's Avatar
2004 Mach 1
Hmm yeah the pic didn't load. Ok, so what does that mean? I see the drop you're talking about. What needs to be tuned on it exactly?
MM Cobra Club #42
Old September 12th, 2008, 10:25 PM   #12
2009 ROTY
AzSonicSnake's Avatar
2003 SVT Cobra
11.07@127
AzSonicSnake has much to be proud ofAzSonicSnake has much to be proud ofAzSonicSnake has much to be proud ofAzSonicSnake has much to be proud ofAzSonicSnake has much to be proud ofAzSonicSnake has much to be proud ofAzSonicSnake has much to be proud ofAzSonicSnake has much to be proud ofAzSonicSnake has much to be proud of
Send a message via AIM to AzSonicSnake Send a message via MSN to AzSonicSnake
someone needs to get ahold of capn' crunch...
MM Cobra Club #25 My Autolog Profile
Old September 12th, 2008, 10:40 PM   #13
Reloaded's Avatar
2004 Mach 1
I was just thinking that when I saw that he was on here now... Haha.
Hoping he'd find my thread.
MM Cobra Club #42
Old September 13th, 2008, 04:15 AM   #14
Reloaded's Avatar
2004 Mach 1
Quick update for this evening. I'm giddy like a school girl! Willie from Sniper sent me an e-mail about all the stuff that he changed (It was like chinese to me. Best I can tell, something about using parts of an 04 Cobra tune), as well as a new tune. Well I just got back from the test run, and all I can say is WOW. Throttle response is way better, the idle is back to normal and under WOT there is no longer a hesitation. It almost feels like there's something keeping it from going faster, but no hesitation. It feels WAY stronger and faster over all, and so much smoother. Just wanted to give a BIG thanks to Willie, and I'll be sending him an e-mail shortly to thank him as well. Also, thanks to everyone for suggestions. I'll probably end up doing some of the stuff that has been suggested here and on SVTP just to do it because I should. Anyway, have I mentioned lately just HOW MUCH I LOVE BOOST????
MM Cobra Club #42
Old September 13th, 2008, 05:57 AM   #15
2009 ROTY
2003 SVT Cobra
11.07@127
don't ever count on that.. honestly. no knockin anyone, but he can keep busy. hit him up directly if you have a question..
btw- glad to hear you finding results! i just found some good results in my car tonight. yeah, seems like my motor mounts have been garbage for quite some time. no rubber left in either one! haha.
Old September 13th, 2008, 09:43 PM   #16
2002BLGT is on a distinguished road
Send a message via AIM to 2002BLGT Send a message via Yahoo to 2002BLGT
Called Pat at Sniper , gotta give him credit to find the problem , he told me what to check , D gain on the fuel pump , he said set it to 0 and it should clear up the hesitation , and on the fuel thats the only thing I changed other than changed the timing just a tad to better match but a little lower than what the 04 cobras run stock because of the non forged pistons
Old September 13th, 2008, 10:41 PM   #17
Reloaded's Avatar
2004 Mach 1
Thanks again!
MM Cobra Club #42
Threads Similar to: Question regarding hesitation (Tune info) Eaton swap @WOT
SCT Xcal2 Air/Fuel at WOT question throwedoff 99-04 2 May 9th, 2007 09:50 PM
5.0 Swap. Help? [Info Only] Texan_Stud V6 Mustangs 30 March 12th, 2007 11:12 PM
WOT switch question thewayshemoves 99-04 4 December 17th, 2006 09:02 AM
351 swap info militarygt 5.0 Mustangs 0 August 20th, 2006 08:47 PM
