max power on stock 03/04 cobra's pistons
Home Register FAQ Members List Calendar Timeslips Blogs Garage Gallery Auto Loans Search Today's Posts Mark Forums Read Auto Escrow
LinkBack (3) Thread Tools
Old September 17th, 2008, 03:13 PM   3 links from elsewhere to this Post. Click to view. #1
03snakeminated is on a distinguished road
this dude that works at murays speed and custom, told me the pistons in our cars are only good to about 550-600 rwhp, he supposedly "knows" about our cars but i highly doubt his statement is true, what i think as long as we do the head cooling mod, heat exchanger, this blocks could handle more than that maybe up to 700, need your guys input on this one
  Reply With Quote Quick reply to this message
Old September 17th, 2008, 05:30 PM   #2
MM's Orangest
Mach Boy's Avatar
2004 Mach 1 Mustang
Mach Boy has a spectacular aura aboutMach Boy has a spectacular aura about
I'm pretty sure they can handle more than 600. People throw all sorts of boost at those engines and they just don't bust.
Looking for 03/04 4V ABS Wiring Harness Connector/Incomplete Wiring Harness (with ABS connector)
Old September 17th, 2008, 05:42 PM   #3
November 08 ROTM
buddyantunez1's Avatar
2000 3.8L Mustang
195.9/220.8 hp/tq N/A
buddyantunez1 will become famous soon enoughbuddyantunez1 will become famous soon enough
Send a message via AIM to buddyantunez1
ive seen stock motors handle 1000+rwhp. check out hellion's system; twin chrged termi's
~Nitrous is like a Hot Girl with STD's, you know you wanna hit it, but your afraid of the consequences~
Old September 17th, 2008, 05:46 PM   #4
N/A 4v Guru
Doc8224's Avatar
2003 Mach 1
Doc8224 is a jewel in the roughDoc8224 is a jewel in the roughDoc8224 is a jewel in the rough
Yea the short block is good past a thousand. So is the 02-04 lightnings
Military Crew
U.S. Army Aviation
Apache's Lead The Way
Old September 17th, 2008, 07:51 PM   #5
Genibus Nitito Canus
HBK_2007's Avatar
2009 Ford Mustang GT
HBK_2007 will become famous soon enough
Send a message via MSN to HBK_2007
just about any ford factory FI cars are damn near bulliet proof as far as the shortblock goes
Red 1996 GT: JLT RAI, Steeda Underdrive pullies, Stewart Waterpump; nothing to brag about
Black 2009 45th aniverary edition GT 5 speed: K&N CAI, BBK Twin 62mm Throttle Body, BBK Underdrive Pullies, SLP Loudmouth
Old September 17th, 2008, 10:45 PM   #6
1000 with stock internals ^^ i think that's exaggerating, just my oppinion, i have heard 700rwhp maybe 800 pushing the envelope and with meth
Old September 17th, 2008, 11:57 PM   #7
rk_2000_Z/28's Avatar
2003 SVT Cobra
rk_2000_Z/28 is a glorious beacon of lightrk_2000_Z/28 is a glorious beacon of lightrk_2000_Z/28 is a glorious beacon of lightrk_2000_Z/28 is a glorious beacon of lightrk_2000_Z/28 is a glorious beacon of lightrk_2000_Z/28 is a glorious beacon of light
No really. There are guys making 900+ to the rear wheels just by pulling the blower and adding a twin turbo kit. See the post below this that I quoted. These motors will hold quite a bit as long as you run the right fuel and have it tuned properly.
03 Cobra-Slow
02 SS, 00 Z/28-Gone
Rest In Peace Travis Billings
Old September 18th, 2008, 02:53 AM   #8
mm's nitrous mod
SWEET2KSTANG's Avatar
2000 mustang gt
11.79@115.83 (old set up)
iTrader: 8 reviews
they will handle a lot, it also depends on set up and tune as well. the compound boost termi was hitting 1100+rwhp on stock bottome end, but that is a totally different set up. the positve displacement blower adds stress to the rotating assembly and drag on the motor, it makes around equivilent power thru the motor just a little less to the wheels.
wagon burner built! track times coming soon!(04 lightning)
follow shop builds on facebook at: MP2 Performance
Old September 18th, 2008, 03:02 AM   #9
November 08 ROTM
2000 3.8L Mustang
948rwhp on a stock motor
Old September 18th, 2008, 06:34 AM   #10
N/A 4v Guru
Doc8224's Avatar
2003 Mach 1
Why would it be exagerating? It is all forged and an iron block. You can't improve on it very much.
Military Crew
U.S. Army Aviation
Old September 18th, 2008, 07:30 AM   #11
awesome, stock pistons and reliable setups?
Old September 18th, 2008, 10:44 AM   #12
Derek@DRI is on a distinguished road
No, the guy at Murrays Speed & Custom is correct. The safest HP level you want to take an 03-04 Cobra is 600-700rwhp. Have Cobra's made more than that on a stock motor? Yes, is it safe and reliable? NO. The Crank and Connecting Rods are good (Forged Steel Crank and Manley H-Beam Rods), the pistons are not. You will find way more stories of failed Cobras than of not past the 700rwhp level. I know because I have seen it happen from customers first hand. My 03 Cobra last at 600rwhp, unfortunately I developed the infamous tick in the cylinder head so I rebuilt my motor since it was already out. Anyhow if you are looking to make over 700rwhp definitely have a back up plan.
Old September 18th, 2008, 02:52 PM   #13
97 Cobra
acidtonic will become famous soon enoughacidtonic will become famous soon enough
Dont forget we are talking about the block here and not the other things that might need to be upgraded to achieve these higher numbers....
If you do nothing but throw lots of boost you will break something because for instance the fuel system needs upgraded. Leaning out might be the reason some have thrown rods when in fact the block would have been fine if the fuel kept up.
Better cooling would be needed at higher numbers, better spark, better tune, different intake or maf upgrades for crazy numbers.
But the block would take it stock if the proper systems keeping the motor alive and running would be at the correct upgrade level.
Just something to keep in mind since I'm seeing generic answers.....
Old September 18th, 2008, 03:42 PM   #14
Mickey's Avatar
Mickey is a splendid one to beholdMickey is a splendid one to beholdMickey is a splendid one to beholdMickey is a splendid one to beholdMickey is a splendid one to beholdMickey is a splendid one to behold
its not just about power...its about power delivery as well. With that, I have seen multiple 800+rwhp cobras on the stock block
Cammed, Slammed, and Blown
Old September 18th, 2008, 07:07 PM   #15
what i meant initially is hp capabilities before going inside the engine, i know about upgrading the fuel system,the tune and so forth, head cooling mod is a must i heard, but other than that engine stock internals are good up to??
Old September 18th, 2008, 07:10 PM   #16
the reason i am asking this is because my goal would be one day to be in the 650-800rwhp range and be able to run mid to low 10's at minimum
Old September 18th, 2008, 08:02 PM   #17
97 Cobra
You said the block, not the stock fuel/cooling setup on the car
The block can take more than some of the other stock components which is why I tried to be more specific since other people would have failure without some other upgrades which would not be the correct answer for just the block.
Those people saying it breaks at Xrwhp would be wrong if it broke because the fuel leaned out for instance.....
Just trying to get you a more accurate answer my friend
Old September 18th, 2008, 08:14 PM   #18
thanks, so whats your take on this? #'s
Old September 18th, 2008, 08:57 PM   #19
97 Cobra
Well mine is a 97 but I've also heard 1000rwhp is easily attainable on the stock block with the proper upgrades. I think that the block will hold that without blowing up but there will be greatly accelerated wear.
What you are most likely more interested in would be the 700-800rwhp figure where it seems to last much longer between rebuilds.
I've seen a mix of both though in terms of reliability. Some running 1100rwhp that lasted 3+ years and those running 500rwhp that lasted 4 months.
I think it really depends on how exact and skillful the builder was and perhaps the difference in quality from one internal part to the next. All companies have a weak part come off the assembly line here and there.... Hopefully that can be found before it leaves but sometimes it doesnt. Same reason a guy found a complete chicken head in his Mc Ds bag... To think it got out of the factory like that, into the deep fryer like that, dumped out into the bin like that, and placed into the food bag without getting caught.
We like to think quality control catches something that passes through many hands before the customer but like everything shit happens.
The quality of your tuner/builder and luck with your internal part quality really determines what you will get. No broad answer really. Ask others before throwing 1000rwhp at it and complaining to me when it breaks.... Do your homework.
Old September 20th, 2008, 04:05 PM   #20
2Slow4U's Avatar
2010 Mustang GT
UNK
2Slow4U is on a distinguished road
Send a message via MSN to 2Slow4U Send a message via Yahoo to 2Slow4U
My 2 cents....your goal is mid to low 10's. This is an easy task. My 03 Cobra Dynos at 545 to the wheels running 10:84 at rockingham. The engine had 24000 miles and the short block is all original. Good luck....But the Cobra short blocks are VERY durable...
Human Verification
LinkBack to this Thread: http://www.moddedmustangs.com/forums/4v-svt/89271-max-power-stock-03-04-cobras-pistons.html
Stock piston info links - Lightning Forum | LightningRodder.com This thread Refback January 31st, 2013 10:16 PM
Stock piston info links - Lightning Forum | LightningRodder.com This thread Refback February 16th, 2010 12:42 PM
Untitled document This thread Refback July 18th, 2009 04:28 AM
Threads Similar to: max power on stock 03/04 cobra's pistons
Max power through a stock GT box Lazyracer 2005 - 2010 13 November 12th, 2010 10:46 AM
max horse power mannymustang V6 Mustangs 16 April 17th, 2008 12:07 PM
Stock pistons steve_metz@yousq.net 5.0 Mustangs 13 March 24th, 2008 02:36 AM
Max Power of an N/A 2V 4.6l? MasterOfEvil 99 - 04 62 April 29th, 2007 03:30 PM
Max power Racerchik02 V6 Mustangs 27 April 28th, 2007 08:19 AM
Forum is powered by vBulletin ©2000 - 2015, Jelsoft Ent. Ltd. & SEO by vBSEO 3.3.2 ©2009, Crawlability, Inc.
