Metco Double Bearing Idler Pulleys
Old September 23rd, 2008, 04:20 PM   #1
Derek@DRI is on a distinguished road
Thumbs down
Metco has released their new re-designed Double Bearing Idlers for the 03-04 Cobra, 99-04 Lightning, and any Mustang using a 8 or 10 Rib Supercharger system. That includes the Shelby GT500. We just got a set in today for a customer and they look real good.
You might ask yourself do I need to upgrade my idlers? Well if you are running stock idlers than keep in mind that under stress these idlers have been known to fail and split. If you currently have the single bearing idlers, than you can upgrade to these double bearing idlers. One of the common problems with the single bearings idlers when used in high boost applications is the single bearing is not sufficient for the added belt loads and thus fails. If you have ever heard a bad pulley bearing you know how annoying the squeak can be.
Another great feature of the Metco Double Bearing Idlers is the belt surface and the back side of the pulley is hard coat anodized for a long lasting finish. The idlers also include dust covers to keep dirt and debris out of the bearings ensuring them a long lasting life.
Give us a call today or click the link to order.
Metco Ford Double Bearing Idler (90mm or 100mm) [MIPDBR] - $89.99 : Performance Parts - Ford Mustang - Cobra - Dodge Viper - Chevy Corvette - C6 - LS1
Threads Similar to: Metco Double Bearing Idler Pulleys
Anyone have Metco billet LCAs? LV51FER 2005 - 2010 3 July 7th, 2008 11:39 AM
question about idler pulley greenstanggt99 4V / SVT 4 June 29th, 2008 07:40 PM
Anyone use Metco Control Arms? energiesource 99-04 8 January 5th, 2008 02:03 AM
Idler Pulleys Underdrive pulleys? 96GtGoodz 96-98 4 November 19th, 2007 11:02 AM
