wheel spacer with drag wheels???
Old September 27th, 2008, 11:55 PM   #1
04 mustang cobra
killerSVTcobra is on a distinguished road
i traded some a car for some cash and wheels. what i got was some knock off weld pro stars with 275/50/15 m/t et streets. they came off a 00 gt. he told me he has cobra breaks. well not the same brakes as me because i put the wheels on and they fit but they rub on the bolt that holds the brake hose on the caliper. thats kind of an important piece so i better keep it there. my question is can you run like a 1/4" or 1/2" wheel spacer with these types or wheels?
If you cant hear the whine, then your behind
Mods: solid axle with 3.73's, MGW shifter, bassani cat-back, afco heat exchanger, k&n fipk, C&L intake tube, accufab throttle body with s.c. inlet, 2.76 upper pulley, 90 mm aux idler pulley, sct tuner
Old September 28th, 2008, 01:15 AM   #2
Diabeetus's Avatar
Black 2001 Cobra
Diabeetus will become famous soon enoughDiabeetus will become famous soon enough
Send a message via AIM to Diabeetus Send a message via Yahoo to Diabeetus
Ive heard of some people grinding that bolt a tiny bit to fit 15s. But personally Id either get Gt brakes, or get rid of the 15s and get some 16 inch Bogarts. The latter is my plan.
Black 2001 SVT Cobra
Solid axle
"Good judgment comes from experience, experience comes from bad jugment"
MM Cobra Club Member #1
Old September 28th, 2008, 01:16 AM   #3
Kamdon's Avatar
Kamdon is on a distinguished road
It's called the banjo bolt. I shaved mine down.
Threads Similar to: wheel spacer with drag wheels???
Wheel Spacer Studs MustangMatt96GT 96-98 13 June 4th, 2010 03:43 PM
Wheel Spacer D3v0n V6 Mustangs 16 May 14th, 2009 10:16 AM
wheel spacer adaptor tmoute 5.0 Mustangs 0 May 8th, 2008 04:33 PM
Wheel Spacer 99cobradroptop 4V / SVT 4 April 27th, 2008 10:11 AM
wheel spacer notsoslo5.0 5.0 Mustangs 7 March 26th, 2007 02:00 PM
