need belt size for a 2-80 upper and 2lb lower w/upr idler
Old September 30th, 2008, 12:17 AM   #1
03snakeminated is on a distinguished road
does anybody have a part number from napa or belt size and brand? any help would be appreciate it.
Old September 30th, 2008, 12:43 AM   #2
04 mustang cobra
killerSVTcobra is on a distinguished road
when i did a pulley swap i just figured out how long my belt was that i had been using, looked at the tensoner stop tabs and guestemated about where i needed to be and went to the parts store and bought 2 different belts then used the one that put the stop tabs closest to the middle..then returned the other one...someone will tell you one thing and someone tell you another, i was told two different things and both were wrong
If you cant hear the whine, then your behind
Mods: solid axle with 3.73's, MGW shifter, bassani cat-back, afco heat exchanger, k&n fipk, C&L intake tube, accufab throttle body with s.c. inlet, 2.76 upper pulley, 90 mm aux idler pulley, sct tuner
Old September 30th, 2008, 07:38 PM   #3
could i still use the same belt i got now if i only go with a 2lb lower.? and whats the best belt non-slip (or less slippery) brand?
Old September 30th, 2008, 09:01 PM   #4
04 mustang cobra
i like the gaterbacks....you could try to use your stock belt. try to put it on and if its too short or long, then just look and see about how much too short/long it is. figure out how long yours is with the numbers that are on it. i think the belts come in 1/2 inch incraments. then just go up/down a size or two...i dont know if you can use a aux. idler pulley with the stock upper..i think they run into each other. i dont have a lower pulley just an 2.76 upper with 90 mm aux idler. if you go to goodyear gaterbacks website they have a chart with tons of different belt sizes
Old October 1st, 2008, 08:36 PM   #5
2003 Cobra
1StockGT is on a distinguished road
Send a message via AIM to 1StockGT
I used CobraBobs website. Here's the link. Alot of useful info in there. If you look to the left there is a belt selection guide. Most people use either a Goodyear Gatorback or a Gates.
Threads Similar to: need belt size for a 2-80 upper and 2lb lower w/upr idler
03-04 cobra.... would i need a diff alternator pulley with a 2lb lower? 03snakeminated 4V / SVT 4 September 19th, 2008 03:40 AM
UPR Upper & Lowers the real shocker 99-04 7 October 2nd, 2007 05:29 PM
lower and upper intakes 02ponypackage V6 Mustangs 0 September 9th, 2007 09:48 PM
upper lower notsoslo5.0 5.0 Mustangs 9 December 15th, 2006 06:54 PM
