shims for 26 spline input shaft T56??
Old September 30th, 2008, 01:29 PM   #1
04 mustang cobra
killerSVTcobra is on a distinguished road
i am buying a liberty 26 spline input shaft for my 04 cobra with the t56. liberty also sells a shim kit for this shaft. my question is has anyone else done this swap and did you need the shim kit?? if you pull out your input shaft and just put in the new one shouldnt it already be set up for the recommended end play? the bearing race on the trans. case cover for the input shaft has a shim under it from the factory
If you cant hear the whine, then your behind
Mods: solid axle with 3.73's, MGW shifter, bassani cat-back, afco heat exchanger, k&n fipk, C&L intake tube, accufab throttle body with s.c. inlet, 2.76 upper pulley, 90 mm aux idler pulley, sct tuner
Old September 30th, 2008, 03:55 PM   #2
Derek@DRI is on a distinguished road
I would definitely get the shims, they are only $20. Chances are you might need them any how, most we end up needing them. Just remember to shim it properly or it will wipe out the bearing. We have the instructions uploaded on our site, and also have them in stock if you need one.
Derek
Old September 30th, 2008, 08:10 PM   #3
04 mustang cobra
Derek
yeah im gonna buy some..what are they gonna run deliverd to my door.
sioux city ia, 51106....just need a quote...they seem to be priced about the same every where.
Old September 30th, 2008, 10:10 PM   #4
2001 cobra
01whitecobra is on a distinguished road
Send a message via AIM to 01whitecobra
yeah you WILL need the shim kit. you can see what the original shims were in the trans and that will give you a baseline, then just work from there. while you are doing the input shaft it might be in your best interest to swap the throw out bearing retainer sleeve since they are known to fail as well. i have seen some carnage when they decided to sheer off.
Old October 1st, 2008, 08:37 AM   #5
04 mustang cobra
i wanted to but the funds are a little less than i would like...do you need to re-shim the main-shaft bearing??
Old October 1st, 2008, 09:58 PM   #6
2001 cobra
then you are going to either be waiting for the shim kit, or you can install it with whats in there and take a chance it will work or FUBAR the new input shaft that you just installed.
i think i only used 2 or 3 of the shims for mine i can see and make you a deal on the remainder of the shim kit and you can make it work.
Old October 1st, 2008, 10:08 PM   #7
04 mustang cobra
lol...im just a cheap a$$ and didnt want to buy the bearing retainer..but i got them both
Old October 1st, 2008, 10:13 PM   #8
2001 cobra
the throwout bearing can seize on the retainer sleeve when that happens the retainer will sheer off at the base. let me upload some pics showing the difference.
Old October 1st, 2008, 10:35 PM   #9
2001 cobra
Threads Similar to: shims for 26 spline input shaft T56??
which is better liberty or d&d 26 spline input shaft killerSVTcobra 4V / SVT 1 August 27th, 2008 05:45 PM
Whats the difference between 31 spline and 28 spline?? BREEZY B 99-04 18 May 31st, 2008 07:01 PM
input spline MATT02GT 99-04 4 February 20th, 2008 10:33 PM
input shaft prob shadowgames81 5.0 Mustangs 1 May 18th, 2007 11:33 PM
