Discussing F1A on 2001 cobra in the 4V / SVT Forum. is it possible? can i buy a procharger D-1sc kit and get an upgrade? ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
2001 svt cobra
12.84@110
F1A on 2001 cobra
is it possible?
can i buy a procharger D-1sc kit and get an upgrade? would the 03/04 kit work on my 2001
![]() steeda tri-ax, alum. drive shaft,caster/camber plates,eibach pro springs,cia, jms chip,4.10 gears,solid axle swap, 31 spline axles,lakewood uppers and lowers,o/r h pipe,flowmasters,MSD 2-step,SLP line lock,front and rear coil overs |
unstoppable @ speed of light
They sell them for the Mach's... should only require a little fabrication... But I'm just guessing.
Political correctness is a doctrine fostered by a delusional, illogical, liberal minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end. |
Captain Of Team Leg Hump
2006 Mustang GT
In the 13's
Unless you are planning on making huge power, i.e. 700+whp, a D1 would be fine. An F1 Procharger is a bad mofo.
![]() Bassani Crew Member #1 Better to be judged by 12 then carried by six. |
2003 Mach 1 Mustang
13.8@102
yea prolly the one for the mach is better for your car than the one for the termi
![]() mostly stock |
2001 svt cobra
12.84@110
well i think i wanted the F1 because i was looking at a KB, but they only make a little 2.1L for the 01s and my goal is to hit mid 10s. I have heard that the F1 spools up similar to a kb. well more so than the D1 does
An F1 is the shizknit. That's what I want to eventually get once I have the money to afford all the needed mods... I hear they can produce over 30#'s of boost at max!
Where iss at?
2003 Mustang Mach 1
12.89@104.6
With a completely forged motor.
![]() Beautiful |
2001 svt cobra
12.84@110
well yea im gonna build the motor and upgrade the fuel system p&p my heads and some other good stuff
July 08 ROTM/MM's Most Eligible Bachelor
2004 Mach 1
Too Slow
Better get some blower cams too, I reccomend Hi Tech
![]() SNEAKER CREW MEMBER #3 Public Service Announcement: White_Fang has no clue what he is talking about. Please DO NOT take information from this guy. |
2001 svt cobra
12.84@110
blower cams any specific specs i need to look for. not to knowledgable about cams. the more info the better thanks
found this for a little over two grand used 4k miles on it. will this work in my car, he says its a GT block will that matter? will my heads, components bolt up? or just not worth it? Custom MPH manly pistons Manley Rods Federal Mogul Bearings ARP Main Studs GT Block Steel Crank Moly Rings ARP Head Studs Cyro Treated FRRP Pump Canton Oil Pan
You can buy a D1 then upgrade the unit to a F1A. However, you'd have to buy a seperate unit. You can't send in a D1 and have it upgraded. I bought the F1A as a swap for my D1 head unit and cash.
2001 svt cobra
12.84@110
if i bought a P1SC kit for an 01 cobra could i just buy the F1 unit later and bolt it on. will that work? i found a used P1SC kit pretty cheap. just wanna make sure ill be able to use the kit for a little while before i get my motor done. then install motor and F1 at the same time.
#13 | |
2002 mustang gt
i have no idea
you do not need an f1 to see 10s.. they have eaton 03 cobra's that do it still on the irs.. shit you can do a built motor and 150 shot and do that if you have a solid axle and the most needed driver mod. and a d1 is good for i think 25 pounds of boost..i have a friend with a 03 cobra just full exhaust(stock rear and stock gears),2.3 whipple(only makeing 593/572) and ran a 10.8 on 17in drags.. so you dont need to spend all that money on a f1 unless you just want to say you have 1.. built motor,d1, heads,some mph cams, good suspension, and if you can drive you can make it there and you can put down more than 550hp.. more like a lil over 600 depending on how much boost you want to run..
![]() 2002 MUSTANG GT 4:10 GEARS PI3500 STALL BORLA CATBACK O/R H-PIPE JLT COLD AIR HEADS AND CAMS(sold)..JUST A LIL 20SHOT OF JUICE NOW ![]() www.myspace.com/playamade |
2001 svt cobra
12.84@110
well i like the way that sounds much better than spending a ton of money on an f1 set up i can find a used d1 pretty cheap build a 650HP capable motor a lot cheaper than i thought i needed think im a decent driver 12.84@110 on solid axle, 4.10 gears, jms chip, densecharger cai, and et streets. not really sure if thats good or not but i was pretty darn excited about it lol
Black 2001 Cobra
Smitty, PM sent buddy.
Black 2001 SVT Cobra Full 2003 body kit HID headlights and fogs K&N filter Catted X-pipe Weld-in Magnaflows MGW shifter "Having a black car is like having a retarded child, it requires extra attention" |
2002 mustang gt
i have no idea
yeah thats pretty decent and you already have a soild axle..yeah built motor and a d1.. you some shocks and struts..unless you wanna do coilovers.. and you can do it easily..
2001 svt cobra
12.84@110
oh man now im really excited my wife will be really happy to hear this. my build budget was gonna be a lot bigger than that i thought YAY!!!!
2002 mustang gt
i have no idea
hahaha....send me a pm on what you are trying to do to your motor.. what heads and what cams and how many lbs of boost
03 mach 1
13.2@109
a KB 2.1 is more then enough to make it to the mid 10s, and you can just change the lower intake manifold and put on the big Kenne bell for the 03/04s cant you
2003 Mach 1, 5 speed MM MACH 1 CREW ![]() "Dont worry ive locked horns with this fucker before"- TasteMyThunder www.myspace.com/mustangracr94 |
Threads Similar to: F1A on 2001 cobra
| 2001 Cobra vs. 2003-4 Cobra | kstills | 99-04 | 24 | May 26th, 2008 09:10 PM |
| 2001 Cobra vs 1999 Cobra | airforcebjf | 4V / SVT | 24 | April 17th, 2008 11:29 AM |
| F1A? | mystang0673 | 99-04 | 0 | November 17th, 2007 04:25 PM |
| 76mm Single Turbo Cobra vs. F1A Mach1 | TheBlkMach1 | Multimedia | 5 | November 12th, 2007 12:20 AM |
| procharger f1a | Drgnracin72 | Poweradders | 8 | April 15th, 2006 02:01 AM |
