03/04 and 99-01 mid pipe
Old October 8th, 2008, 07:22 PM   #1
smitty's Avatar
2001 svt cobra
12.84@110
smitty is on a distinguished road
are the termi and the 99-01 factory mid pipes the same or not? i need a factory catted mid pipe for my 01 for smog testing and have found an 03 for a pretty good deal but just wanted to make sure it will bolt up ok
tri-ax, alum. drive shaft,caster/camber plates,cia, SCT chip,4.10 gears,solid axle swap, 31 spline axles,UPR control arms, UPR A-arms, flowmasters,MSD 2-step,SLP line lock,front and rear coil overs 307rwhp,309rwtq
MM New Edge Cobra Club Member #4
Old October 8th, 2008, 10:23 PM   #2
N/A 4v Guru
Doc8224's Avatar
2003 Mach 1
Doc8224 is a jewel in the roughDoc8224 is a jewel in the roughDoc8224 is a jewel in the rough
The cat position is a little different as is the 02 sensor location. get a 99-01 gt mid pipe and you will be good to go.
Military Crew
U.S. Army Aviation
Apache's Lead The Way
Old October 9th, 2008, 02:35 AM   #3
smitty's Avatar
2001 svt cobra
12.84@110
well like stated above i found good deal on an 03 cobra mid pipe. but you dont think this will work?
Old October 9th, 2008, 03:10 AM   #4
N/A 4v Guru
Doc8224's Avatar
2003 Mach 1
Yea it will work but the 02's are in a different spot and I am not sure if your 02 wires will be long enough.
Military Crew
U.S. Army Aviation
Old October 9th, 2008, 11:32 AM   #5
Derek@DRI is on a distinguished road
Actually the 04s are the ones which require 02 ext, you should be good to go with an 03 mid-pipe.
Threads Similar to: 03/04 and 99-01 mid pipe
Mid-Pipe Lefty General Tech 7 February 16th, 2008 07:11 PM
Mid-Pipe armymike63b 99-04 5 November 17th, 2007 11:22 AM
Has Anyone Used This Mid Pipe? 01 GT 99-04 5 November 16th, 2007 10:27 PM
mid pipe stangitis General Tech 9 October 3rd, 2007 06:01 PM
which mid pipe SilverGT04 99-04 5 August 13th, 2007 10:05 AM
