Clutch And Flywheel Kit
Old October 9th, 2008, 01:32 AM   #1
Look Ma! My First Post!
dcruz1255's Avatar
2004 FORD SVT COBRA
dcruz1255 is on a distinguished road
Which Clutch And Flywheel Kit Would Be The Best For My 04 Svt Cobra ???
Old October 9th, 2008, 01:33 AM   #2
Is the game, Ross is the name.
6DXR's Avatar
1998 M3,2K8 Ninja 250
Faster Than Fapsmith's Asian Girl
6DXR is a name known to all6DXR is a name known to all6DXR is a name known to all6DXR is a name known to all6DXR is a name known to all6DXR is a name known to all
Send a message via AIM to 6DXR
Postin in the wrong section brother.
Try the 4V section.
I drive a 1998 BMW M3. I used to drive the sexiest Mach 1 in existence. But now I am a 3uroslut
Old October 9th, 2008, 11:28 AM   #3
Derek@DRI is on a distinguished road
How much power are you making? Also is it a Daily Driver, Street/Strip? Let me know and I can help you out.
Old October 10th, 2008, 02:04 AM   #4
04 mustang cobra
killerSVTcobra is on a distinguished road
Try the 4V section.
this is the 4v section isnt it?
If you cant hear the whine, then your behind
Mods: solid axle with 3.73's, MGW shifter, bassani cat-back, afco heat exchanger, k&n fipk, C&L intake tube, accufab throttle body with s.c. inlet, 2.76 upper pulley, 90 mm aux idler pulley, sct tuner
Old October 10th, 2008, 03:12 AM   #5
mm's nitrous mod
SWEET2KSTANG's Avatar
2000 mustang gt
11.79@115.83 (old set up)
iTrader: 8 reviews
the stock flywheel is an aluminum piece with a steel insert. i would run a stock flywheel and depending on power output will effect on what clutch is recommended.
Old October 10th, 2008, 12:25 PM   #6
04 mustang cobra
if your stock flywheel is still good you can use that but you cant change the steel clutch pad on them and the factory replacement is $610 list. you can get an aftermarket one that weighs the same and you can change the steel clutch pad for around $300-$350.
Threads Similar to: Clutch And Flywheel Kit
clutch & flywheel ?'s Squints 5.0 Mustangs 16 May 22nd, 2008 01:42 PM
Clutch / Flywheel sgrcltpunk 99-04 17 April 1st, 2008 01:27 PM
New Clutch w/ Flywheel ??? Montanasvt 4V / SVT 8 January 25th, 2008 01:12 AM
Brand New Clutch and Flywheel mustang1072 99-04 8 November 9th, 2007 11:48 AM
? about Centerforce clutch and flywheel WilltheThrill 99-04 4 February 20th, 2007 04:07 PM
