cobra stock input shaft
LinkBack (1) Thread Tools
Old October 10th, 2008, 10:22 PM   1 links from elsewhere to this Post. Click to view. #1
03snakeminated is on a distinguished road
what are the limits with the stock 03-04 cobra input shafts? i see a lot of folks upgrading them, is there a time when you reach so much hp/tq that you must upgrade?
Old October 10th, 2008, 11:02 PM   #2
2003 Cobra
1StockGT is on a distinguished road
Send a message via AIM to 1StockGT
I'm not sure what the hp/tq area people are doing them, but I'm going to change mine when it's time for a new clutch.
Old October 11th, 2008, 12:20 AM   #3
04 mustang cobra
killerSVTcobra is on a distinguished road
i dont know what im making for power now but the 2nd night i had the 2.76 pulley, i was in 2nd gear about 2000rpm, hit the gas and at about 4ooo rpm or so the tires (315 sumitmo htz) started to spin. it got to about 5700 rpm and i was getting ready to shift to third and all of a sudden i hear this clunck and the motor was hitting the rev limiter at 6850. right away i knew what it was. i thought they mainly broke on hard launches...guess not. easy to swap out.
If you cant hear the whine, then your behind
Mods: solid axle with 3.73's, MGW shifter, bassani cat-back, afco heat exchanger, k&n fipk, C&L intake tube, accufab throttle body with s.c. inlet, 2.76 upper pulley, 90 mm aux idler pulley, sct tuner
Old October 11th, 2008, 06:14 AM   #4
562cobra's Avatar
2003 Mustang Cobra
562cobra is on a distinguished road
they should have come stock with the 26 spline instead of the 10. some sites say to switch it out when you reach 500hp/tq. I myself would switch it off sooner. i.e. when transmission work is done, tranny fluid change, etc.
MM Cobra Club Member #28
Old October 13th, 2008, 11:50 AM   #5
Patrick@LCR's Avatar
97 Mustang, 98 Cobra
pretty darn fast
Patrick@LCR is on a distinguished road
Send a message via AIM to Patrick@LCR
I'm somewhat with you on this one. There's not any exact number as to what it will hold, or when you must upgrade, as some people could have a lot more power but ease into it, and some with less just thrash on it. 500 is around what I'd think, but your experiences may vary.
It's not too difficult to install, and if you're getting a new clutch/flywheel or have reason to be around that area, you could always toss it in with the install for a couple bucks more at your local shop.
LinkBack to this Thread: http://www.moddedmustangs.com/forums/4v-svt/92509-cobra-stock-input-shaft.html
cobra stock input shaft This thread Refback October 13th, 2008 11:52 AM
Threads Similar to: cobra stock input shaft
Input shaft bearing or the TB rabihgt 99-04 1 October 2nd, 2008 09:59 PM
shims for 26 spline input shaft T56?? killerSVTcobra 4V / SVT 8 October 1st, 2008 10:35 PM
which is better liberty or d&d 26 spline input shaft killerSVTcobra 4V / SVT 1 August 27th, 2008 05:45 PM
Looking For input on 97 Cobra Elder 96-98 12 September 17th, 2007 11:46 PM
input shaft prob shadowgames81 5.0 Mustangs 1 May 18th, 2007 11:33 PM
