LinkBack (1) | Thread Tools |
#1
2004 mach1
ok guys i just went to go look at a 04 mach 1 18,000 mile $14,000. but here's the thing it got to engine codes 1. P0060 and 2. P0174. and on the traction control button the light is lit but when you push the button it does not turn off. and last the abs light is on how can you check to see whats wrong with it? thanks
MM's Ford Truck Guy
99 ranger,2010 ranger
does nice burnouts
the best way is to go 2 advanced auto they can tell you what the codes meen just ask them to see there code booklet they have behind the counter i used 2 work there a while ago so i should know lol good times man haha
![]() 1999 xlt 2.5 ranger lowered 5/6 on 17in bullits 2010 4.0 xlt ranger lowered 4/5 on 18in dd bullits |
#3 | |
I.D.G.A.F.
Find out if the guy has a tuner, if so then you can check for codes, and correct the traction control issue. Good luck scouring the car, and welcome to the 4v family.
RIP Travis Bilings 5/6/1982-7/5/2011 Be polite. Be professional. But have a plan to kill everyone you meet. |
it has an offroad h pipe. aftermarket mufflers. no paint over spray. ever thing else is fine
and there is like a hollow poping in the exhaust
14k for an 04 with 18k may be to good of a deal, you get what you pay for remember theres a reason he has it low, it could cost you more in the end than finding one for more but in perfect condition, keep it in mind, im waiting till the perfect car comes along till i get one, not necessarily the best price
06 Saleen s281: 3.4 pulley, 39lb inj. KB BAP, steeda cai, steeda belt tensioner, saleen extreme inlet tube, bassani x, magnaflow, MGW, brenspeed tune |
well the dealer just got the title. he got it at auction i think. it was repowed. and the trad in is $13555. the dealer sells the cars at whole sale.
MM's Orangest
2004 Mach 1 Mustang
Are you sure it is P0060? The other code is a running lean code due to the o/r pipe.
![]() Looking for 03/04 4V ABS Wiring Harness Connector/Incomplete Wiring Harness (with ABS connector) |
yea. he read the codes for me there.
MM's Orangest
2004 Mach 1 Mustang
P0060 HO2S Heater Resistance (Bank 2, Sensor 2)
MM's Orangest
2004 Mach 1 Mustang
Have them fix the TC. And have them look at the heater resistance code. The running lean one you will have to take care of on your own with a tune, or buy a catted midpipe.
what would be needed to fix the code and how much do you think a mid pipe will go for
MM's Orangest
2004 Mach 1 Mustang
Catted midpipe is $450ish or you can go get a tune that will make the car run faster and get rid of the DTC for about $700 give or take. If you plan on modding the car at all fork over the cash for the tuner.
so you think its worth getting?
I.D.G.A.F.
If you don't have to pass an emissions test then keep the o/r h pipe
well i know a few people around me that do the test's. and wouldnt i be able to get the catted pipe and switch to the off road pipe after inspection?
N/A 4v Guru
2003 Mach 1
The reason the TC is on is because it has a tune on it and they set the TC off, but someone forgot to turn off all the 02 functions. Get the actual handheld if you can because it is married to your car and you will not be able to flash over that tune. If you can get the tuner you can fix all that.
![]() Military Crew U.S. Army Aviation Apache's Lead The Way |
i read that the TC is on because the ABS light is on.
#19 | |
I.D.G.A.F.
N/A 4v Guru
2003 Mach 1
If the light is on then the TC is off. ABS light could be a couple a couple of things, including dirty sensors.
LinkBack to this Thread: http://www.moddedmustangs.com/forums/4v-svt/92570-2004-mach1.html
| 2004 mach1 | This thread | Refback | October 11th, 2008 03:00 PM | |
Threads Similar to: 2004 mach1
| More of the new Mach1.. | BlackSunshine | The Clubhouse | 34 | June 27th, 2008 08:43 PM |
| Mach1 vs SS | Mustang RacR94 | 99-04 | 20 | November 14th, 2007 05:40 PM |
| Few pics: a buddy's 2004 Mach1 | theninja | Pictures | 14 | August 26th, 2007 09:13 PM |
| what is the difference between a 2004 gt and 2004 40th Anniv | coreyfitz | 99-04 | 3 | August 9th, 2007 11:09 PM |
| 73 mach1 | lusty | Classic Mustangs | 4 | February 1st, 2007 10:03 PM |
