Question about a blower setup - Page 2
LinkBack (1) Thread Tools
Old October 12th, 2008, 12:29 AM   #21
mm's nitrous mod
SWEET2KSTANG's Avatar
2000 mustang gt
11.79@115.83 (old set up)
iTrader: 8 reviews
they are a little more teadious. they dont have much forgiveness to them, nor are they leanient either.
Old October 12th, 2008, 12:30 AM   #22
N/A 4v Guru
Doc8224's Avatar
2003 Mach 1
Doc8224 is a jewel in the roughDoc8224 is a jewel in the roughDoc8224 is a jewel in the rough
Modulars aren't that bad if you just take your time,. but effin 4v modulars are expensive to build.
Military Crew
U.S. Army Aviation
Apache's Lead The Way
Old October 12th, 2008, 12:30 AM   #23
I.D.G.A.F.
futureMACH1racer's Avatar
2009 John Deere 9670
futureMACH1racer has much to be proud offutureMACH1racer has much to be proud offutureMACH1racer has much to be proud offutureMACH1racer has much to be proud offutureMACH1racer has much to be proud offutureMACH1racer has much to be proud offutureMACH1racer has much to be proud offutureMACH1racer has much to be proud offutureMACH1racer has much to be proud offutureMACH1racer has much to be proud of
Send a message via AIM to futureMACH1racer Send a message via MSN to futureMACH1racer Send a message via Yahoo to futureMACH1racer Send a message via Skype™ to futureMACH1racer
Yeah, I picked up on that.
RIP Travis Bilings 5/6/1982-7/5/2011
Be polite. Be professional. But have a plan to kill everyone you meet.
Old October 12th, 2008, 12:37 AM   #24
I.D.G.A.F.
Yeah no kidding, Paul from PHP told about an engine that he was building.
5.0 big bore
teksid block
stage 3 fox lake ported heads
custom PHP cams
titanium valvetrain pieces
canton pan w/ windage tray
billet i beam rods
coated forged pistons
forged crank
race quality bearings
etc...
He wants $8500.00 for the motor I install it
Old October 14th, 2008, 02:31 PM   #25
2004 Mustang Mach I
12.11@115.74
oc192 is an unknown quantity at this point
What the max power stock bottom and tranny can support?
Ram Powergrip HD Clutch
Old October 14th, 2008, 02:52 PM   #26
97 Cobra
acidtonic will become famous soon enoughacidtonic will become famous soon enough
5.0 big bore
teksid block
custom PHP cams
billet i beam rods
forged crank
etc...
Whats it making power wise? Sounds pretty bitchin.
Old October 14th, 2008, 05:56 PM   #27
I.D.G.A.F.
That engine there should put down around 430rwhp/460rwtq but that engine can't be sprayed so it's out of the question. It's a badass motor. You can have that engine installed for $13k with everything. On race fuel it should make closer to 450. With as light as your car is Acid it would be like having another 100hp at the tire.
Old October 14th, 2008, 07:18 PM   #28
97 Cobra
I kind of thought about taking the weight even more to the extreme and going NA since I love those cams and it would be more reliable....
But I think I need more power...
I wanted to go twin screw but to get intercooled I need C heads which adds quite a bit to the cost. Plus they favor the lower compression which really limits me from changing my mind since NA/Turbo/Centri would prefer slightly higher compression. I'll admit when it comes to changing my mind, I'm like a woman so best to keep my options open. Something like 9.[0-4]:1 comp.
I've been thinking about the single turbo route again but building for no lag vs. high power. Been studying compressor maps and such trying to find the absolute smallest fastest spooling turbo that wont surge. Like a single 57mm or even smaller just for the quick spooling properties without ruining the turbo. I'm seeking 2000rpm quick response for the street. I want more average power over the band than peak.
I dont have to have more power than the TS, I just want to stick with B heads, get the small boost in mpg which would probably push me over 30mpg with the weight, and have some instant power to play with. Due to the low weight I think that would be a fun combo plus recently I've really started to favor the sound. Being able to change boost without getting out of the car is also attractive.
Just my thoughts this week
LinkBack to this Thread: http://www.moddedmustangs.com/forums/4v-svt/92618-question-about-blower-setup.html
Question about a blower setup This thread Refback October 12th, 2008 12:15 AM
Threads Similar to: Question about a blower setup
Post your blower setup! mustang_montana General Tech 51 July 9th, 2009 01:28 AM
blower question flattusmaximus78 5.0 Mustangs 2 October 6th, 2008 01:13 PM
blower question? screwed by twins 5.0 Mustangs 20 June 24th, 2008 10:06 PM
Hypothetical Blower Question 03GTguy 99-04 25 April 15th, 2008 09:12 AM
just looking out: cheap blower setup nes General Tech 7 December 25th, 2007 11:42 PM
