LinkBack (1) | Thread Tools |
2 diff dynos 2 totally diff readings
sucks that the previous dyno i took the car (i wasn't there) the guy gtuned the car and gave me the dyno slip and showed the car made 488/478tq and yesterday just for shits an giggles since they were running a special, i took the car to another dyno and in the base run car made only 445/440tq, they both were dynojets and weather was pretty much the same if not warmer the first time, now why so much of a difference? its only been about 43 days
SAE smoothing maybe? What does the sheet say for both?
![]() Current mods:
MM Bullitt Crew Founder and Member #1
Honeybadger is Crazy
Could've been alot of things, were you there the first time?
RIP Travis Bilings 5/6/1982-7/5/2011 Be polite. Be professional. But have a plan to kill everyone you meet. |
#4 | |
Tech Exchange Head Honcho
2003 SVT Cobra
11.70 @ 121
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 3 reviews
KB'd GT
40hp can easily be due to different IAT and ECT temps.
Saving up for another one
did they drain your intercooler and then ice it yesterday?
no i wasn't there the first time, and no icing the ic, i think the dyno from yesterday is way off, idk maybe needs to be recalibrated, 445hp its freaking low for a ported, pullied 2.80 and 2 lb lower eaton, then he tuned to 475/481tq, and that was squeezing every little bit of fuel through stock pump and injectors, no more could be had, i was there and he added more timing too then what i had.
im sure the intercooler not being iced is part of the problem.
'03 Cobra, '89 +'91 Notch
11.63@120.08, Cobra
Dyno operators can make the dyno read whatever they want to. Thats why dyno's aren't a good indicator of what kind of power your car is making. They are good tuning tools but people rely on dyno #'s too much. I'm also not a big fan of icing the blower or putting ice in the I/C res. Kinda seems like cheating to me.
Although I do ice my blower at the track. lol I took my Cobra to a local dyno day and my Stage IV ported, 2.93, 4# lower car put down 449rwhp and 479rwtq, no ice, no fans. With the Stage IV port and a 2.76 upper only my car put down 491/467 on a different dyno previously. So just for comparison a guy I know put his freshly built 347 stroker on the dyno and he put down 324rwhp and like 370 rwtq. Just a few weeks ago my car put down 486rwhp and 517 rwtq on yet another dyno also with no ice and no fans.. Just goes to show you the difference. Oh and one other point. Even the TIRES you use can cause different readings. Some Drag radials and slicks will show lower numbers than street tires due to the sidewall flex.
+1 Boost, I remembered that as soon as I read your post.
that sucks if the first tuner iced out the intercooler and didn't tell me, (just to read higher hp numbers), i should of been told, that deff could be why the numbers were off, I'm glad i stuck around this time,(without icing the i/c he got me 475) i learned something new, now i know a trick to be Faster On Race Day, so by just icing that sucker i should see maybe 10-15 extra ponies?
not like that's going to matter a lot, but it's alway good to know
#13 | |
![]() according to the dynojet at RET, mine (nonported stock air tube, stock TB, stock plenum, 2.8 upper w/100mm idler, stock lower pulley) put down 11 more hp and 12 more tq to the rear wheels after draining and icing the intercooler
#14 | |
it will when youre going up against a well modded ls1 car
#15 | |
2003 SVT Cobra
I don't yet know what your prize is, but you nailed it. A 40 HP difference is quite large but not unbelieavable when jumping from dyno to dyno.
![]() 03 Cobra-Slow 02 SS, 00 Z/28-Gone Rest In Peace Travis Billings
This isnt suprising news. Ive seen this a thousand times. This is why i dont even waste my money or time with chassis dynos.
that sucks that they can make it read what they want
#18 | |
11.63@120.08, Cobra
lol
Your prize was rep from me.
LinkBack to this Thread: http://www.moddedmustangs.com/forums/4v-svt/94002-2-diff-dynos-2-totally-diff-readings.html
| 2 diff dynos 2 totally diff readings - Page 2 | This thread | Refback | November 11th, 2008 07:55 AM | |
Threads Similar to: 2 diff dynos 2 totally diff readings
| need help with diff.... | 88stangGT | 5.0 Mustangs | 3 | May 16th, 2008 01:38 AM |
| ET diff with 4.10 vs 3.73 | njstang | 99-04 | 8 | May 6th, 2008 04:29 PM |
| Power diff. between H and X? | Countryboy_99 | General Tech | 3 | January 2nd, 2008 03:41 AM |
| diff between pi and non pi motor | BoostHard1210 | 99-04 | 29 | June 13th, 2007 10:15 PM |
| How much diff will it get you? | scxc15 | V6 Mustangs | 8 | May 20th, 2007 03:38 AM |
