LinkBack (1) | Thread Tools |
#21
I.D.G.A.F.
I hope that he would get some Fox Lake Ported Heads, and some MPH Blower cams, as I have been referred by numerous people as they are the best for the money.
RIP Travis Bilings 5/6/1982-7/5/2011 Be polite. Be professional. But have a plan to kill everyone you meet. |
#22 | |
13.86@100.3
i like fox lakes and most likely id have MPH do the cams because all i hear is good things from them.
2004 40th Anniversary GT Pro 5.0 Shifter Lowered(H&R Springs) Summit Hpipe w Dynomax weldin mufflers Minor odds and ends |
#23 |
N/A 4v Guru
2003 Mach 1
If you are having cams custom ground and heads custom ported, then just decide what power adder you are gonna go with and they will make the heads and cams to work with that combo. If you go centri blower or turbo, a good intake manifold will come into play as well. I would check out sulivan for that, they have some realy nice stuff. If you aren't gonna drive it much on the street then stick with the c-4 or c-6, don't go with an overdrive or electronic overdrive tranny. it's just not something you need or realy want for a drag setup. Just get the tranny built realy well (like Art carr) get a trans brake and a good stall.
![]() Military Crew U.S. Army Aviation Apache's Lead The Way |
#24 |
wow an 8 sec street car, thats pretty damn badass man, be careful with it, a guy by me built a 600+ horse camaro, and the first time he took it out, all was going well from what I heard, he got on it, tires span in 3rd or 4th and he wrecked the damn thing the first time he had it out.
but its gonna be a badass car
99 Cobra 03 Cobra motor AFCO H/E Pulley JLT CAI BBK L/T off road H/steeda catback SCT MAF Tune 03 cobra pumps HVGC |
#25 | |
13.86@100.3
#26 |
2011 Mustang GT
12.1 @ 116
Top fuel dragsters use roots blowers...
I'm sure with a little bit of looking around you can find a roots for any amount of power...
Mods in garage. Built suspension and gears since posted times. |
#27 |
48.47@ 12.58
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 10 reviews
I'd use a twin screw. Roots are nowhere as near efficient as a twin screw.
#28 |
13.86@100.3
thats wat meant. 3.4 whipple be enough? or will the 2.8 kenne bell do it? i like the kenne bell better but ill take power over preferance
#29 |
N/A 4v Guru
2003 Mach 1
If you are planning an 8 sec car I would get the big boy whipple. It will be easier with a big centri blower but if you wanna do it with a twin screw then thats what I would do. You need to head stud the motor when you do heads and cams or you could be spitting out head gaskets with all that boost, also do the cooling mod to the motor before you drop it in, If it was me I would put a windage tray in,a bigger/better oil pan, and a race oil pump to ensure the oiling system was up for the task.
#30 | |
13.86@100.3
and i wasnt goin to go w the stock oil pump, but also havent found a oil pump or fuel system i like yet. i may do a custom fuel tank where the spare is in trunk. wat oil pump/system do u guys recommend. btw anything we discuss is saved in files so i only have to ask once.
#31 | |
N/A 4v Guru
2003 Mach 1
#32 | |
13.86@100.3
. i probly will do a lil motor work adressing wat u guys said were the motors week points, piston heads and rod bolts but ive got someone to hire for that because i kno hes good. ill look into meling system. also electric water pump or just up grade belt driven?
#33 |
I.D.G.A.F.
Your going to want to build your shotblock right too. Billet I beam rods, Forged coated pistons, billet oil pump, titanium valvetrain pieces, custom cams, ported heads a massaged intake, splayed billet main caps, windage tray, pan, 1.75" headers, Stainless Steel rings, You're going to end up spending about 10k on the motor its self. Then figure another another 10k for the blower, heat exchanger, fuel system, and radiator. Then you have the trans, converter, the chassis bracing, the rest of the drietrain mods. Slicks, suspension. Son you have about 30k to invest to do it right the first time.
#34 | |
13.86@100.3
#35 | |
97 Cobra
You will need something you didnt have or think you needed. Something wont fit quite right, etc. rinse, wash, repeat. |
#36 |
I.D.G.A.F.
If you're going to tear into the motor do it right. Get billet rods, IDK how much power you plan on making, I have an idea of what it takes to get what you want to accomplish. If you leave the stock internals in there then you will end up building this motor twice.
I'm just trying to help, I learned the hard way.
#37 | |
13.86@100.3
the crank is still goin to be same even if i went aftermarket rite?
#38 |
I.D.G.A.F.
No, you'll be getting stronger parts. Trust me, the internals are the last place that you want to be cheap with.
#39 |
#40 |
13.86@100.3
no that was the reason i chose the 03 motor to build off of. but after this new info would it be just as easy to do a mach 1 motor or am i missin a vital piece of info?
LinkBack to this Thread: http://www.moddedmustangs.com/forums/4v-svt/94682-turbo-cams-vrs-supercharger-cams.html
| Turbo cams vrs supercharger cams - Page 2 | This thread | Refback | October 28th, 2008 10:19 AM | |
Threads Similar to: Turbo cams vrs supercharger cams
| heads and cams with supercharger?? | SilverStang03 | 99-04 | 3 | October 18th, 2008 02:51 PM |
| NSR Supercharger Cams | Kobie | 2005 - 2010 | 102 | August 24th, 2008 09:26 PM |
| Comp Cams SPR stage 2 cams on the way!!! | RStrick0352 | 2005 - 2010 | 10 | August 9th, 2008 02:06 AM |
| Supercharger!/Cams | Killax15 | 99-04 | 9 | February 11th, 2008 04:48 AM |
| Cams/Supercharger | acmillr | 99-04 | 11 | February 16th, 2007 04:59 AM |
