LinkBack (1) | Thread Tools |
13.86@100.3
Turbo cams vrs supercharger cams
Wats the difference? and if u only want to do cams once will turbo cams hurt a s/c motor?
2004 40th Anniversary GT Pro 5.0 Shifter Lowered(H&R Springs) Summit Hpipe w Dynomax weldin mufflers Minor odds and ends |
Honeybadger is Crazy
I believe that turbo cams are the same as blower cams for centri blowers. Positive displacement blowers have specific cams.
RIP Travis Bilings 5/6/1982-7/5/2011 Be polite. Be professional. But have a plan to kill everyone you meet. |
13.86@100.3
Lets make this more clear
I plan on swaping in a 03-04 cobra dohc s/c motor into my car soon. Reasons y are 1. 150k+ of abuse from previous owners. 2 same cost as forged 2v plus more power, 3 they sound amazing w fi. it will be s/c for a while but heads and cams will go on b4 i drop it in. the mods will be by no means be done. i want twin turbos at the end but it will be s/c fora while. will turbo cams hurt the s/c motors performance?
IDK, why go with compound boost? You have your Eaton with twins on top of that. What kind of power are you looking for?
13.86@100.3
wat it takes to run high 8s. i cant seem to find a cobra motor w a s/c that gets outa the high 9s
A whole lot more than just an engine. It takes money mostly, and the faster you want to go the more it costs. You're talking about building a race car. You're going to need some serious brakes, suspension, and chassis work first.
13.86@100.3
yea i kno hence reason im not goin all out at first
A car like that should be built from the ground up
13.86@100.3
yep and im just finishing highschool so itll be piece by piece. im getting a upr adjustable rear suspension at christmas and some 33 spline axles in january w a new set of gears cause of the fucked up install of my current ones
Be aware that the UPR anti-roll bar kit MUST NOT be run on the street or it will be damaged. You need to un-hook the links and tie them out of the way for the street. Youre also gonna have to dump the exhaust in front o the rear axle with that kit as well. If you're looking for high 8's, what transmission do you plan on running?
Black 2001 SVT Cobra Solid axle "Good judgment comes from experience, experience comes from bad jugment" MM Cobra Club Member #1 |
I would reccomend a C4 or a powerglide, but's me.
13.86@100.3
built 4r70w. theres a guy on here w one on his 2005+ car
#13 | |
13.86@100.3
Lentech makes a kit, but I don;t know if the 4R70W is strong enough, besides you're building a race car, why not go with a powerglide? They're stronger and more efficient.
#15 | |
13.86@100.3
FB Performance Transmission Pricing question: how much hp will 33 splines hold?
Then you arent looking. I know alot of guys running 8.50s with superchargers and stock bore/stroke 4.6s.
13.86@100.3
videos, threads, anything would be helpful
Do you realize how much money you're looking at spending to get into the 8's? You're looking at about $20k
13.86@100.3
yea i have and its more then that. i priced it all once. i know itll several years to complete. its a dream. it should have begun jan of this year but a wreck of my honda and economy have forced my dad and i to hold off on it, but i plan on gettin a bike for a dd and i have a ranger that my gdad left us for days i cant use the bike.
N/A 4v Guru
2003 Mach 1
As far as you original question, no a turbo specific grind will not hurt an eaton powered car. As for S/C'd 8 sec cars they are all over the place, not on an eaton mind you, but you don't have to go turbo to get 8's. Also a built 4r70w will handle the power if its built by the right person but you will be better off with a built c-4 c-6, or a built AOD. I wouldn't do a power glide unless its a strip only car but FM1R is right it is about the best for a car that runs those times, especialy a turbo car. You said you where doing heads and cams before you dropped it in? What heads are you planning on putting on it?
![]() Military Crew U.S. Army Aviation Apache's Lead The Way |
LinkBack to this Thread: http://www.moddedmustangs.com/forums/4v-svt/94682-turbo-cams-vrs-supercharger-cams.html
| Turbo cams vrs supercharger cams - Page 2 | This thread | Refback | October 28th, 2008 11:19 AM | |
Threads Similar to: Turbo cams vrs supercharger cams
| heads and cams with supercharger?? | SilverStang03 | 99-04 | 3 | October 18th, 2008 03:51 PM |
| NSR Supercharger Cams | Kobie | 2005 - 2010 | 102 | August 24th, 2008 10:26 PM |
| Comp Cams SPR stage 2 cams on the way!!! | RStrick0352 | 2005 - 2010 | 10 | August 9th, 2008 03:06 AM |
| Supercharger!/Cams | Killax15 | 99-04 | 9 | February 11th, 2008 05:48 AM |
| Cams/Supercharger | acmillr | 99-04 | 11 | February 16th, 2007 05:59 AM |
