2007 Mustang GT
pistons/rods.....???
hey guys im sneaking in the 4v section to get some info lol..........Im building an engine for my 07 GT, thinking strongly about using Termi rods (found a good deal).......my question is do the GT pistons work with the Termi rods?? i found a good deal on a set of brand new Mahle flat tops for a 3v, thats why i am wondering. thanks
Bassani Crew Member #3 |
are the pistons bored?
1999 Mustang Cobra (rebuilding, someday...) 1996 civic dd [/SIZE] ![]() MM Cobra Club #3 |
2007 Mustang GT
what do you mean bored?? they are standard size pistons, are the wrist pins different sizes or something??
you dont bore a piston, you bore a block, youd just buy pistons that are for the bored over car, wouldnt you?
2003 Mach 1, 5 speed ![]() U.S. Army - 11B "And on the 8th day god created the infantry and all hell stood at attention" |
2007 Mustang GT
yea i understand what SIZE pistons i need (im going standard bore).........i was looking for a quick answer to IF a piston made for a GT will fit on a stock Termi rod or if i would have to get pistons made especially for the termi
Honeybadger is Crazy
The 3v and 4v use the same rotating assembly parts so I'm lead to believe.
RIP Travis Bilings 5/6/1982-7/5/2011 Be polite. Be professional. But have a plan to kill everyone you meet. |
from what I know they all use the same rods , so it should work fine , even the 2v use the same rods from what I have seen
2007 Mustang GT
i think you guys are right..........looking around on websites like Wiseco and JE all the piston pin diameters are the same from 2v, 3v, and 4v pistons, all stroke lengths are the same, so i am lead to believe a 3v piston will work with the termi rods.........thats good because a local MM member has a killer deal on some that i cant pass up..........next question, how much HP will the stock Termi H beams and crank hold up too??
700hp is what they claim, but if you're buying thme then get better pistons.
mm's nitrous mod
2000 mustang gt
11.79@115.83 (old set up)
the manley rods from the termi's will work just fine. they are standard 5.933 rods. the manley rods are rated for 800hp at 8k rpm's.
Threads Similar to: pistons/rods.....???
| 03/04 Rods & Pistons on my 01 | Lefty | 4V / SVT | 16 | November 8th, 2008 08:41 PM |
| pistons and rods 4.6 | 94stang | 99-04 | 26 | February 19th, 2008 07:46 PM |
| pistons rods | Bhblondguy | 2005 - 2010 | 11 | November 7th, 2007 06:46 PM |
| Pistons Rods | Bhblondguy | 2005 - 2010 | 3 | November 7th, 2007 02:50 PM |
| Pistons Rods | Bhblondguy | 2005 - 2010 | 0 | November 5th, 2007 11:08 PM |
