LinkBack (1) | Thread Tools |
#1
99 cobra clutch
My clutch is making a loud squeeking noise and im guessing its fixing to go out. So i have a series of questions
What clutch should i get? I am extremely tight on money right now. 1. Clutch i should buy 2. How much does it cost 3. How hard and time consuming is it to put in by yourself. Your help is GREATLY appreciated
MM Cobra Club #20 1999 Cobra - Custom black/silver paint, 18" chrome Saleen wheels, BBK CAI, H-pipe, bullet mufflers, FRPP 4.10's and 305 Nitto DR's |
I.D.G.A.F.
It more than likely your throwout bearing.
RIP Travis Bilings 5/6/1982-7/5/2011 Be polite. Be professional. But have a plan to kill everyone you meet. |
how would i go about fixing this myself? How much does that cost
Disconnect the battery
To take the shifter off Pull the mid-pipe off pull the driveshaft Undo the motor mount bolts disconnect the tranny wire harness unbolt the starter pull the tranny remove the pressure plate remove the flywheel I put in the last 2 cause I don't know how many miles are on the clutch. But like Mach1racer said its probably the TOB. But since its apart you might as well replace the clutch. Clutches range anywhere from 190$ to 500$. All depends on what you do with the car (.i.e. daily driver, street/strip, race car, high hp, etc..) -Mark
![]() -Mark- 98' N/A Cobra (Stock longblock) 11.79 at 114.64 (1.62 60ft) |
i found a king cobra for 240, is that a good price? Mostly daily driver but occasionally strip
The disk on the King Cobra kit is organic. I'd get a more agressive disk. Maybe something of kevlar. A proven combo has always been a FRPP pressure plate and a mcCleod kevlar disk. Very similiar to a spec stage 2 setup. Still give you streetability but will hold agressive launches.... to a point. -Mark
thank you
LinkBack to this Thread: http://www.moddedmustangs.com/forums/4v-svt/99208-99-cobra-clutch.html
| 99 cobra clutch | This thread | Refback | November 27th, 2008 08:01 PM | |
Threads Similar to: 99 cobra clutch
| 04 mustang cobra clutch | killerSVTcobra | 4V / SVT | 13 | September 11th, 2008 04:48 PM |
| 98 cobra clutch conversion? | trvsg55 | 96-98 | 5 | August 19th, 2008 09:59 PM |
| King Cobra Clutch | Drick | 5.0 Mustangs | 9 | September 8th, 2007 02:26 AM |
| new clutch for 1995 cobra | arice | 94-95 | 8 | March 22nd, 2007 02:12 PM |
| ? about clutch replacement of my cobra | WilltheThrill | Modular Mustangs | 14 | January 25th, 2007 07:41 PM |
