p0171 p0174 codes 03 cobra
got a 03 cobra with cai and cat back, seems to be burning alot of fuel and tripping computer codes p0171 p0174 codes.i have cleaned the maf with maf cleaner and also have checked for vacume leaks,nothing found so far, any help or ideas ?
Assistant to the Manager
I believe those are lean in bank 1 and 2 codes . . . . But i could be wrong
Join The MM Facebook: Modded Mustangs Facebook Vote For Modded Mustangs Ride of the Month Eskimo Brothers To Smooth: Safi, Blitz34, Graystang01, WillTheThrill, Bwal, 101Fng |
Tree Fiddy Z
it is lean...
i know the codes po171 po174 are lean codes bank1 and bank2,i am trying to find out what could be causing these codes.could it be dirty 02 sensors,bad maf or vacume leak or somthing else.so far i cleaned the maf with maf cleaner and could not find a vacume leak so far. any ideas would be great thanks.also the car is runing rich because the computer sees a lean condition.
Tree Fiddy Z
start with cleaning the MAF if you didn't find any vacuum leaks
Does the car have a tune on it?
think i found the problem, the egr valve was leaking so i replaced it and cleared the codes ,i will let everybody know if it works, thanks.
the egr was the problem,there was a air leak where the egr mounts to the blower, the gasket was not sealed properly, the egr was probaly alright but the new egr with gasket was pretty cheap so i replaced it anyway and no more leaks,I found leak by spraying brake clean all aruond the motor while it was running and as soon as the car died found problem.cleared codes so far so good.
2009 ROTY
glad i deleted mine! the block plate i put on there won't leak. oh, and before you tell me the emissions part, i just went through yesterday with no problems.
Threads Similar to: p0171 p0174 codes 03 cobra
| Acceleration Issues - P0171 | cgyarring | V6 Mustangs | 3 | November 16th, 2008 06:54 PM |
| Cobra color codes | energiesource | 99-04 | 5 | July 28th, 2008 06:19 AM |
| code P0171 | bbrewer03 | 96-98 | 6 | December 2nd, 2007 06:52 PM |
| P0171,P0174 | Clay | 99-04 | 4 | October 2nd, 2007 05:58 PM |
| p0171 code | 96gtponyred | 96-98 | 7 | August 24th, 2007 12:03 AM |
