The Doctor
'01 Cobra Vert.
What Tranny Fluid?
Okay guys, I just searched around to see what I could dig up... Found this:
tranny fluid ? My question to you guys. I have the stock tranny on my 01 cobra (I believe its the T-3650 if i'm not mistaken); that thread I included in here has a bunch of different types of fluid floating around in it. There doesn't seem to be a common type that a group of people are using. What fluid should I use in my transmission? I've heard GM Syncromesh is good. But I'm open to others as well. Thanks
2001 svt cobra
no way (IRS)
3.25 quarts non-synthetic!
Build #1249 MM New Edge Crew Member# 6 |
The Doctor
'01 Cobra Vert.
I was also wondering this, for my mach tho. What brand to use?
Because I'm the best there is at what I do, and what I do best isn't very nice. |
Priest of the Car Gods
Why non-synthetic? I've been thinking about switching my T-45 over to redline, haven't yet out of sheer laziness.
O o /¯/______________________ |BLAAAAAAAAAAAAAAAAAAAAAAAAARGH!!! \_\ Buy my Bronco, special deal for MM folks |
97GT & 97Snake & 00L
T.B.A
i am using b&m trick shift...works good...
![]() 97 Cobra & 00 Lightning Beauty & The Beast I rev next to hybrids so they can hear me kill the environment ![]() MM Cobra Club Member #77 MM Lightning Club Founder |
2001 svt cobra
no way (IRS)
the tremec-3650 is a different animal, I used rp synthetic and ended up removing it.(that fill plug is a B by the way) I ended up just using regular auto store brand auto. tranny fluid and is shifts very smooth. This really only go's for us w/ the tr-3650 which was used in the 01 cobras and the 03/04 mach 1s I know for sure.
The Doctor
'01 Cobra Vert.
I heard GM Syncromesh is good...??
Any Mercon III fluid is fine (I think thats what the manual says for the 3650) Stay away from synthetic fluids for the tranny. Wears on the syncros twice as fast.
![]() -Mark- 98' N/A Cobra (Stock longblock) 11.79 at 114.64 (1.62 60ft) |
2001 svt cobra
no way (IRS)
thats right mercon 3, any brand should do
![]() ![]() ![]() ![]() iTrader: 13 reviews
My second gear was rough as hell to get into and my 3rd was grinding just a little bit. I replaced my trans fluid with Valvoline Mercon V. And well it shifts a whole of a lot better then before. Ford recommends Mercon III or V. I believe they used to recommend III but now its V but either will work.
#12 | |
Why is synthetic is causing premature synchro wear, and is that only with the 3650?
For the T45 its weird. My 98 manual says mercon V but 97-96 manuals call for for Merc III. When I broke my new tranny in I put in Merc V then switched to Merc III and it seems to shift smoother. But I think either one will be fine for the T45.
As far as synthetic fluids, let me find the article I found while I was researching fluids. I'll post the link when I find it. -Mark
2011 Mustang GT
12.1 @ 116
3.8 Quarts of Mercon V. Yes, Mercon V.
You can always cheat and just pour all 4 quarts into the transmission through the tailpeice of the transmission by taking the shifter off. It'll make a mess because it'll drain itself through the fill plug which is what you want. Get it on 4 jacks, completely even and square. Drain the transmission through the drain plug on the bottom (3/8'' ratchet). Clean the Plug and screw it back in there and get it nice and snug. Now up on the passenger side there it a plug near the rear of the tranny. You'll see it. It says "Fill". Unscrew that. Go into the car and take your shifter console out, take the heat gaurd off the shifter, take shifter off and you'll see a 'cup' and right behind that you'll see a small hole going into the transmission. Pour the fluid in there. What I did was took a gallon ziplock and made a splashgaurd and surrounded the console by taping it down, then I got a funnel and poured the fluid through there. Fill it up untill it starts pouring out of the fill hole. Wait for it to stop, plug it back up, have fun. Also, before yo ucrank the car, shift through the gears with the car off for a few seconds. Then after creanking the car, run through the gears while parked. Get it all worked around before you drive it.
Mods in garage. New mods, new track times soon. |
The Doctor
'01 Cobra Vert.
So Mecron V for my stock 01 Cobra tranny?
...just double checkin'
2011 Mustang GT
12.1 @ 116
I have the T3650... You have the same as I do. Trust me. Mercon V. It's what I've had in there since the sycnhro rebuild and haven't ground a gear yet.
#17 | |
The Doctor
'01 Cobra Vert.
Mercon V? Haven't heard of that one lol. Think I'm gonna try a Mercon III and see what that does.
#19 | |
Saving up for another one
does that apply to the t-56's also? |
2001 svt cobra
no way (IRS)
tell me if I am wrong, but mercon V is synthetic is it not?
Threads Similar to: What Tranny Fluid?
| tranny fluid ? | Mustang Racer | 99-04 | 8 | November 7th, 2008 02:52 AM |
| what tranny fluid? | Bandit | 2005 - 2010 V6 | 4 | April 28th, 2008 04:45 PM |
| tranny fluid | GTsetGO | 99-04 | 2 | March 23rd, 2008 06:02 PM |
| tranny fluid | 96gtponyred | 96-98 | 4 | August 8th, 2007 05:49 PM |
| What Fluid do you use in your T5 Tranny? | noyz25 | 5.0 Mustangs | 6 | August 6th, 2007 05:25 AM |
