LinkBack (1) | Thread Tools |
#1
can i benefit from mixing 104 unleaded with 93 octane?
trying to squeeze a lil bit of power, right now i am at 485hp 495tq on 93 octane tune(2.80 upper,2lb lower ported eaton) i was thinkin about using 110 leaded fuel but that now is out of the equation, i bought a 5 gallon pale of 104 gt unleaded, and was thinking about doing a 50/50 mix with 93 octane and retuning car, do you guys think i would be able to hit 500hp with the added benefits of higher octane? some of you might think i'm racing numbers but to each his own, thanks for your input guys
bump
anyone?
you will so almost no power gain by running the higher octane period, without the correct tune you'll get almost nothing what so ever, and if your tuned for 93 octane im not sure if you can even run higher without causing damage
but no you wont see any additinol power
2003 Mach 1, 5 speed ![]() U.S. Army - 11B "And on the 8th day god created the infantry and all hell stood at attention" |
Priest of the Car Gods
Do you have any examples to back this up? It's my understanding that running higher octane than you're tuned for is still okay; it's running lower octane that will cause issues.
O o /¯/______________________ |BLAAAAAAAAAAAAAAAAAAAAAAAAARGH!!! \_\ Buy my Bronco, special deal for MM folks |
I have no idea...I tried and looked some information up on Google and found nothing what so ever.
myspace.com/garrettstarnes 2004 4.6 engine. Cold air intake. Stage2 clutch. Spec Flywheel. Intake spacer. Throtle Body spacer. More to come! |
thats why I said im not sure about when you go up in octane, only down
not sure how I worded it, but i meant it to sound like I didnt know if it would hurt if you ran higher octane, but I know lower does, as far as power I dont think it would add any benefit to power, not sure if it would hurt anything running higher octane, but I just wanted to say I guess its a possibility, im just not sure
i'm not spending all that money on race gas and leaving the same parameters, the car is getting retuned for the higher octane there has to be some gains with the added timing, how much? I don't know, that's what I was hoping, a rough estimate from some of you guys
MasterDeBater
Mixing fuel is not something i would do if you want to make 500 hp it should be fairly easy with the numbers your making. I believe you can make about 20 + more hp with some super high octanes
Join The MM Facebook: Modded Mustangs Facebook Vote For Modded Mustangs Ride of the Month Eskimo Brothers To Smooth: Safi, Blitz34, Graystang01, WillTheThrill, Bwal |
Blown 03 GT
Running higher octane will do nothin good, It can hurt fuel economy though. The fuel being harder to burn may not burn completely.
I overheard someone said that up to 95 or 96 octane (i can't remember which) our s/c cars should see some gain, more than that its not as beneficial unless you are turbo. Now that could probably be a full load of crap, but I don't know.
1996 Mustang GT coupe
11.99@113.93mph
also different brands of fuel Do Not blend well and could actually cause you problems, I'd avoid doing it....
Thumbdinger.com Fish With Protection
Blown 03 GT
Its all about the tune. the car is setup to get the most power out of the setup without detonation for a certain octane level. If you increase it you dont increase the capabilities of the tune just the fuel. A slight increase will make it safer depending how high strung your tune is but now power gains.
thanks ^^^^ , I am getting the car dyno as i type, i'll let you all know how it did.
MasterDeBater
He said he was getting a tune for it which means it ofcourse would help. Running a higher octane without tuning for is a waste of gas
2003 Mustang GT
12.28 @ 116
![]() ![]() iTrader: 11 reviews
looking forward to the results
![]() 2003 Sonic Blue GT---SLP Longtubes, SLP X, Magnaflow Magnapack CB, 75mm TB/Plenum, MP2 Performance stage 2 heads, MHS Stage 3R cams, Built rear w/4.30's |
if you get it tuned for the higher octane, you can see benefits, but without the tune, i dont beleive you will at all
lets just say car doesn't like race fuel, it made the same power with all the tuning,tweaking and whatnot, I guess it wasn't meant to be
2008 GCSRT8, 1965 Coupe;
not unless you have a tune for it... and make sure it isnt leaded or you can really fuck shit up....
What did the tuner do with the timing?
LinkBack to this Thread: http://www.moddedmustangs.com/forums/4v-svt/99833-can-i-benefit-mixing-104-unleaded-93-octane.html
| can i benefit from mixing 104 unleaded with 93 octane? | This thread | Refback | December 3rd, 2008 01:55 AM | |
Threads Similar to: can i benefit from mixing 104 unleaded with 93 octane?
| octane mixing | 07 STROKER | 2005 - 2010 | 10 | July 31st, 2008 10:37 AM |
| add/remove timing for 104 octane? | Modern_Muscle | 2005 - 2010 | 17 | April 21st, 2008 02:54 AM |
| Leaded vs Unleaded | JASonic | The Clubhouse | 15 | April 5th, 2008 11:46 AM |
| Diesel vs Regular Unleaded Gasoline | mustang fanatic | 2005 - 2010 | 33 | March 12th, 2008 01:20 PM |
| mixing gas | mu5t4ng | 96-98 | 6 | January 6th, 2007 01:34 AM |
