LinkBack (2) | Thread Tools |
#1
The Razor's Edge
Aluminum Radiators and electric fans
FLUIDYNE
79-93 RADIATOR, FLUIDYNE, ALUMINUM, MUSTANG MUSTANG mishimoto and i havent found a fan for less than 300 bucks.... |
1992 Lx
11.39@119.24
mine was 30 from a junkyard
My original factory brass/copper 2 core cooled my 470RWHP S/C'd mustang with A/C and I only replaced it because it was 20 years old and started leaking. You won't get any style points with an OEM looking radiator but they work fine.
I did get an aluminum one but only because I found this one for not much more than a 3 core stock replacement. I've had it for about 8 months now and no problems. It was a drop in replacement. The only thing I had to do was trim some rubber from the upper brackets because this rad is slightly wider at the top.
#4 | |
Flex-a-lite 175 - Flex-a-lite Direct Fit Electric Fans - summitracing.com
![]() Join Date: Oct 2008
There are generic radiators that fit in our cars perfectly. I ran an upgraded 3 core stock replacement and never had any problems with it for years. Also, look into junk yard electric fans. You'll be surprised at how well they flow when compared to name brand aftermarket fans.
The Razor's Edge
you wanna gimmie a turbo kit for a 351w notch?
#7 | |
The Razor's Edge
if i can find my self to spend 500 bucks on a radiator and fan it would be worth it in the end
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/100046-aluminum-radiators-electric-fans.html
| Ebay 4 You » Blog Archive » Aluminum Radiators and electric fans | This thread | Pingback | December 6th, 2008 10:25 AM | |
| Easy Auction Ebay » Blog Archive » Aluminum Radiators and electric fans | This thread | Pingback | December 5th, 2008 08:08 PM | |
Threads Similar to: Aluminum Radiators and electric fans
| Electric Fans... | DIRTYD | 5.0 Mustangs | 12 | December 22nd, 2007 09:40 PM |
| Aluminum Radiators??? | JONJON | 5.0 Mustangs | 20 | November 8th, 2007 10:18 PM |
| eLECTRIC faNS | javier351lx | 5.0 Mustangs | 30 | September 13th, 2007 10:03 PM |
| Electric Fans | javier351lx | 5.0 Mustangs | 15 | July 15th, 2007 03:10 PM |
