Need advice on 331 build
Old December 6th, 2008, 02:08 AM   #1
foxstang is on a distinguished road
Im building a 331 turbo motor and was wondering if I could get some input on what would be a good set of heads to run. Im planning on running about 6psi on the street and hopefully 14 or so at the track. This is the kit I was planning on running so if you have any opinions on it throw them in too if you could. Thanks
Dart Block
Pro-street 331 Probe Rotating Assembly
INCLUDES:
• Forged Steel Crankshaft
• Probe SRS Forged Pistons
• Race Rings
• Probe Forged 4340 Rods (H-beam)
• CL77 Bearings
89' 306 W/ Edelbrock performer 5.0 heads, BBK SSI intake, F-303 cam, 75mm MAF, 75mm TB, 30lb injectors, 255lph fuel pump, BBK afpr, BBK shorty headers, Off road X-Pipe, Flowbastards, and 3.73 gears.
Old December 6th, 2008, 02:26 AM   #2
The Razor's Edge
White Thunder's Avatar
afr 185
founder of the FTN Club
Old December 6th, 2008, 07:26 AM   #3
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Originally Posted by White Thunder View Post
afr 185
Why?
Old December 6th, 2008, 10:02 AM   #4
Racinjason81 is on a distinguished road
why dont you just stickwith the edelbrocks?they are 170cc heads on the slightly smaller
side but a ton better than the stockers.you should ditch that ssi intake for something that will move more air like a holley systemax or trick flow r series,at least get the ssir upper intake.you will need to step up to at least 42lb injectors too.get rid of the flow impeders and install 3.31s-3.55 gears
Heres a real funny video
youtube.com/watch?v=ojB7KkaR03I
VTEC stands for Very Torqueless Economy Car
Honda stands for Hold On Not Done Accelerating
1991 LX 5.0 H/B(T-70 turbo coming soon)
Old December 6th, 2008, 12:34 PM   #5
The Razor's Edge
Originally Posted by Darrell View Post
Why?
correction Trick Flow Twisted wedge
Old December 6th, 2008, 01:16 PM   #6
Brian@PAR's Avatar
Brian@PAR is on a distinguished road
RPM's too small
AFR185's too small
TW only if you bought the TW kit from probe wich I doubt since you already had inline heads.
I would suggest the high port. Ideally the CNC race version but that may be a bit too much for a street car even boosted. The 192cc runner of the street version does not show it's true potential.
If you don't like the special headers you have to use then an RHS215, AFR 205 (not convinced they are worth the money) or even a Vic JR.
You are best served with a large head and 200cc heads run just fine on a street 306 at 10:1 a 215 is no probelm on a 331.
What ever head you choose you should run a custom cam. Billet customs are 450 and worth every penny.
PeteAndersonRacing
Old December 6th, 2008, 01:20 PM   #7
The Razor's Edge
im not the smartest guy on the bored but 205's sound to big to me......
Old December 6th, 2008, 01:50 PM   #8
JBIGBOOTSY's Avatar
1990 LX hatch
I run a 210cc head on a 302.
Old December 6th, 2008, 01:59 PM   #9
That is true
PeteAndersonRacing.com
Old December 6th, 2008, 02:03 PM   #10
The Razor's Edge
dont knock me im here to learn asshole
Old December 6th, 2008, 08:24 PM   #11
No the motor in my sig is not the motor im building im helping a friend build one for him mustang. We were just trying to get some opinions on the build.
Old December 6th, 2008, 11:19 PM   #12
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Dart Block
INCLUDES:
• Race Rings
• CL77 Bearings
How fast do you want to go and how much money do you have to spend? Why only 6psi on the street and 14psi at the track? Why not 14psi everywhere?
I know one thing, I wouldn't buy AFR anything...
Old December 6th, 2008, 11:22 PM   #13
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Too big is a relative term. Too big why? If the engine can use it, its not too big. Small ports, small cams and small intakes make small power.
Old December 7th, 2008, 12:52 AM   #14
91 LX
13.7@101
exactly
Old December 7th, 2008, 01:40 AM   #15
TKOTLARZ's Avatar
1994 GT
TKOTLARZ is on a distinguished road
so big ports ,big cams,and big intakes make big power
Cohagan Engineering, Inc.
Old December 7th, 2008, 02:49 AM   #16
The Razor's Edge
i was really set on a set of afr 185's for a 347 build. i respect what you think.....so tell me why you wouldn't.
im thinking about a mild 347 turbo....maybe just a 302. i know i want a turbo....im just a turbo guy.
i would like to hear what you say...
Old December 7th, 2008, 03:07 AM   #17
TKOTLARZ's Avatar
1994 GT
i would listen to him..he knows his shit..
Old December 7th, 2008, 03:14 AM   #18
The Razor's Edge
ive been around long enough to know that
Old December 7th, 2008, 03:20 AM   #19
TKOTLARZ's Avatar
1994 GT
lol i kno..i can see how many posts u have
Old December 7th, 2008, 03:23 AM   #20
The Razor's Edge
its sad i haven't learned more than i have....i have the worst memory in the world.....and i mean that
Threads Similar to: Need advice on 331 build
What do you boys think of my 331 build so far? cybertech 5.0 Mustangs 20 September 10th, 2008 02:17 PM
Turbo build prep advice.... acidtonic 4V / SVT 13 July 31st, 2008 05:31 PM
How to build a 331 stroker Drick 5.0 Mustangs 10 January 25th, 2008 08:57 PM
Need Engine Build Advice Please coony278 5.0 Mustangs 17 November 13th, 2007 11:35 PM
Gonna build a 331 w TF Track kit... LazerRed_91_LX_5.0 5.0 Mustangs 2 July 29th, 2006 06:40 PM
