1995 Mustang GT
SLOWER THAN OLD PEOPLE FUCK..:-(
oil pressure issue.
okay so since i've had the car the oil pressure has always flucuated, sometimes it'd run at the A in NORMAL sometimes it runs at the O. Just curious if this is something i should worry about or is it just normal. for it to go up and down.
1993 Cobra
11.21@120
sounds like an oil pressure issue
[B][SIZE="3"][FONT="Tahoma"][COLOR="Lime"]I Hate You |
1996,mustang
around 5's 0-60
^ no for real
does it have ticking noise then change your lifters check your oil pump though.
bbk cai 8.8 373 dual exuast ported heads bored 30 over forge crank aggressive cam minor shit also [SIZE="4"][COLOR="Red"]crew member #1 that loves mods and administrators[/COLOR][/SIZE] |
1995 Mustang GT
no it doesn't tick or anything..i'll see if i can get the oil pump checked out.
1992 Mustang GT
Coming soon...
I would be willing to bet its the gauge, they are usually pretty inaccurate. Naturally your motor will lose a little oil pressure once it reaches operating temperature. The only way to know for sure is to hook up a mechanical gauge.
1992 Hatch: 306ci, gt40p's, comp xe270, Edelbrock Performer, 1.6 r/r, full bolt-ons, and some supension work |
What he said
PeteAndersonRacing.com |
#7 | |
I'll tell you what I used to tell my customers back in the day. Ignore the gauge. It's electrical, and doesn't show accurate pressure. It's there pretty much for show, not so much for function. If you want to know or monitor your actual pressure, get a manual gauge. That factory gauge doesn't account for air pockets, spikes in pressure, or changes in engine speed. |
1988 lx
9.68@142
+1 on the mechanical gauge the stock one blows.
1994 GT
the guage moves alot to the slightest bit of pressure change with the stock gauge
Cohagan Engineering, Inc. |
With a new sending unit, my 20 year old factory gauge always read the same as my autometer mechanical gauge (although the increments are much larger). I was surprised.
It is normal for oil pressure to fluctuate with operating temperature. It should be higher when cold and lower when warm. If it is getting close to the red on the low end, then you have a problem. Otherwise, it is fine. If you see it fluctuating rapidly, that is usually because of low oil level.
88 GT CHI headed 351w 10.8 @ 125 - still figuring it out. 03 Cobra 2.3 whipple 10.7 @ 129 - sold it 04 Mach 1 12.7 @ 109 mostly stock - sold it 89 LX procharged 302 515 hp 497 ftlbs 10.7 @130 mph - sold it
1992 Mustang GT
Coming soon...
[QUOTE=ryans88gt;1660512]With a new sending unit, my 20 year old factory gauge always read the same as my autometer mechanical gauge (although the increments are much larger). I was surprised. QUOTE]
Same here...As far as I know my sending unit is the original one, and my factory gauge reads the same as the mechanical I hooked up. I guess I am lucky, because all my friends factory gauges blow.
1990 Mustang GT
13.64 @ 101 MPH
oil pressure will also flucuate with RPM's
![]() 90 Ford Mustang 5.0 T5- BROKE 1.9 60' on street tires13.64 @ 101 MPH 89 Ford Mustang coupe- http://www.youtube.com/watch?v=1nIrzcQz3_8 |
Of course naturally, I ate my own words today...my oil pressure went south in my Bronco on my way home from work, I mean it dropped severely. I was going to add a quart or two, but instead ended up changing the oil. Turned out my filter was clogged with coked oil that got burnt when the motor overheated as a result of tossing the belt the weekend after Thanksgiving.
1994 GT
11.75@120
ever watched the Chevy oil pressure gauge, i laugh every time i get on it
Ford Racing R block stroked 347. Trickflow stage 1 cam, Trickflow street burner upper and lower, gt40P heads, BBk 75mmTB, 03 cobra MAF, Zex dry kit, Tuned by PSI Motorsports, stock valve covers ...E/T: 11.75 @ 120mph 2.0 60foot |
2008 GCSRT8, 1965 Coupe;
go buy a 15$ guage to double check it... you dont even have to mount it if it does it at idle...
#16 | |
if it has done it since he got the car then id say it isn't an actual problem and on top of that as oil ages it can change pressure slightly... Last edited by rwboring; December 11th, 2008 at 09:21 AM. |
Threads Similar to: oil pressure issue.
| no oil pressure | Smirnoff | 5.0 Mustangs | 3 | July 24th, 2008 02:52 PM |
| Oil Pressure???? | sn94 | 5.0 Mustangs | 1 | July 23rd, 2008 09:16 AM |
| 03 Cobra SVT Oil Issue | shawnh531 | 99-04 | 15 | March 4th, 2008 11:34 AM |
| Problem 88LX oil issue. | USARMY1983 | 5.0 Mustangs | 4 | January 9th, 2007 05:35 AM |
| oil pressure | turp | V6 Mustangs | 1 | August 19th, 2006 11:59 AM |
