Buying new heads... need specs and advice
Old December 9th, 2008, 11:23 PM   #1
jjperl is on a distinguished road
Can any one tell me what the bore, stroke, piston cc, and piston type (dished, flat top, etc.) is on a 94 cobra? It has GT 40 heads.
Also what would a good compression ratio be for a 5.0 with a 9psi Paxton?
Basically, I'm looking to buy 165cc AFR cylinder heads and rockers as my next mod.
Here's what I have so far:
---------MOTOR---------
Novi 2000 Supercharger - 9psi
BBK 70MM Throttle Body
RC Racing 38lb Injectors
Walbro GSS255 Fuel Pump
TrickFlow - TFS 1 Camshaft
GT 40 heads
----------EXHAUST-----------
MAC - 1 3/4 primary x 3in collector Ceramic Coated Long Tube Headers
Dr. Gas - 3in to 2.5in Offroad X-Pipe
Bassani - Stainless Aftcat Catback - 2.5in - 3in Polished Tips
--------EEC / IGNITION----------
90MM Lightning MAF
DiabloSport Chipmaster Revolution Chip
Crane HI-6R Ignition and PS92 Coil
---------DRIVETRAIN------------
Fidanza Aluminum Flywheel
Ford Racing 3.73 Rear Gears
Old December 9th, 2008, 11:43 PM   #2
The Razor's Edge
White Thunder's Avatar
there going to tell you not to buy afr...and to get bigger heads and there going to tell you to get a better cam shaft
founder of the FTN Club
Old December 9th, 2008, 11:54 PM   #3
I've made up my mind... I'm going with AFR heads. I just need specs so I can finish filling out a form.
Old December 10th, 2008, 01:49 AM   #4
e3sean's Avatar
1988 lx
9.68@142
Ford Head Flow Data and Specs
this should help you decide which head to get
<font size=4><b>MILITARY CREW
Old December 10th, 2008, 10:14 AM   #5
M L Struck's Avatar
85 GT/86 SVO/2010 GT500
M L Struck will become famous soon enough
That's good stuff
Old December 10th, 2008, 10:17 AM   #6
91 LX
13.7@101
get 185cc AFR......itll be better for boost
Old December 10th, 2008, 12:27 PM   #7
nolife's Avatar
91GT, 88GT, 02GT
You have to consider the whole package.. Plain old as from Ford GT40X heads with 10-12# will exceed what most people would consider safe for the stock block. Better heads would yield more power capability but your block would be pushed to the edge.
Threads Similar to: Buying new heads... need specs and advice
Advice on buying tuner & gears. trueblue02GT 99-04 10 December 2nd, 2008 09:26 PM
thinking about buying heads for 98 gt mexlatino 96-98 20 November 13th, 2008 08:29 PM
advice with heads tigerfan2771 V6 Mustangs 2 May 2nd, 2008 07:09 PM
Advice On Buying Used '05 ItalianStallion V6 Mustangs 24 November 29th, 2007 10:40 PM
Advice on buying Buegie V6 Mustangs 22 January 3rd, 2007 11:20 PM
