LinkBack (1) | Thread Tools |
#1
1991 Ford Mustang LX
ford explorer heads?
I have to redo my piston rings so i figured while im at it id pop in a b303 cam and gt40 heads of a ford explorer. can i literally just pull them straight off the explorer and bolt them as-is onto my mustang?
BBK CAI and Shorty Headers, Cobra Upper/Lower Intake, Walbro 110, 24# Injectors, larger throttle body, maf, Drilled and slotted front rotors, King Cobra clutch, Cobra wheels w/ sumitomo tires, flowmasters |
1988 Mustang GT / 98 Expo
![]() iTrader: 1 reviews
From what ive been researching yes you can just don't get a set of GT40P (F77E)heads, The angle of the spark plug is different and would require you to buy new headers. A couple easy ways to tell are:
GT40's, have 3 bars on the front the heads and generally have a casting number of (F3ZE, F1ZE) GT40P's, have 4 bars on the front of the heads and if you look on the top of the heads by the push rod holes you'll see a stamping the clearly says GT40P
mods list: Balanced 306, Cobra intake, GT40 heads, TFS1, 1.6 RR's, 70mm TB, 73mm ProFlo MAF, BBK shorties, OR/H pipe, Flowmaster American Thunder cat back, 3:73's, MAF Conversion, CAI, A/C and Smog deleted,
ive heard the gt40s suck compared to the p's, is this true or is it a barely noticeable diff, im not looking for a race car, just something with enough power to have fun so i dont really care if its a 10hp diff
1988 lx
9.68@142
yes the header selection is narrowed but still not a big deal yes the p heads are better due to the spark plug angle being closer to the center of the combustion chamber. if you get a set of heads its smart to bring em in to have em checked out maybe even a valve job to make sure everything seats the way it should. loom into a different cam try to find a trickflow stage 1 or 2 they are everywhere and will be better for your motor.
yeah alphabet cams blow idk how many times i have to say it for poeple to understand
here's a flow chart i had posted in another thread which shows the difference between the e7, gt40 and gt40p heads. and listen to these guys when they say to avoid going with a ford letter cam. especially a b303, that's barely better than stock.
[SIGPIC][/SIGPIC] [SIZE="4"]"This just in....14.79 @ 92.15 is not fast"[/SIZE] |
1989 Mustang LX
10.98@126.7 NA
They don't blow. There are better cams but dollar for dollar, they are still heads above the stock cam. We were getting mid 12's with an F303 and stock bottom end with some reworked E7 heads. The next best value would be Trick Flow
Never fast enough.
#8 | |
With a set of GT40s capping it off What springs should i look into gettin to handle the lift of the cam?
i replaced my f303 with an anderson n-41 and would do it again in a heartbeat
you sound like a magazine*L*....all the abc cams are way better than stock if you have the right components..though I don't like any of them..how was that test conformed on the heads? you can do minimal work on the gt40 if you have them to flow very well
EVERYONE IS ENTITLED TO MY OPINION:cool: 6'ers are for kids 1965 chevelle SS 421 sbc 6 speed, 3.90 gears,alum d-shaft, brodix heads,roller cam,925 AED carb...grocery getter*[COLOR="Red"]RIP[/COLOR]* |
^ dude, that chart is just showing stock numbers. all i said is i wouldn't waste the time, money or effort installing a b303 cam. you said yourself you don't like letter cams so what the fuck is your point?
1994 GT
11.75@120
There not terrible, they are just older technology so you might as well go with trickflow 1 or 2
Ford Racing R block stroked 347. Trickflow stage 1 cam, Trickflow street burner upper and lower, gt40P heads, BBk 75mmTB, 03 cobra MAF, Zex dry kit, Tuned by PSI Motorsports, stock valve covers ...E/T: 11.75 @ 120mph 2.0 60foot |
1989 Mustang LX
10.98@126.7 NA
Their main drawback is that they are single profile cams and they tend to be conservative. They have been around a long time and considering they are factory replacement pieces designed to fit a wide range of applications, they are decent performance upgrades. As far as spring upgrades, I believe that the Trick Flow upgrade kit will work on the GT40P's and are good to .542" of total lift.
Never fast enough.
1993 Mustang
we'll find out when i come home from iraq.
what about the X cam lol
shut up before i punch you in the throat |
^ you tell us
1992 Lx
11.39@119.24
im very happy with my tfs 1 cam, i like the powerband alot, pulls all the way to 6k and hardly lost any low end
#17 | |
Ive also been thinking about the AFM N-41 and N-412 i know they're similar. But what heads are you running on your car?
1993 Mustang
i dunno i just bought the car while im over here in iraq. im gonna run it for a while and see if i like it or not. if i don't ill prolly switch over to a tfs cam.
anyone have experience w/ the x cam?
i was running the n-41 on gt40p heads
1994 GT
u can also look into a custom cam..it isnt much more money than the cam ur lookin at, and its made perfect for your setup..look into that for real.
Cohagan Engineering, Inc. |
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/101096-ford-explorer-heads.html
| ford explorer heads? | This thread | Refback | December 13th, 2008 12:44 PM | |
Threads Similar to: ford explorer heads?
| 1997 ford explorer | sweetrolls | All Other Vehicles | 4 | September 11th, 2007 02:23 PM |
| Explorer heads, What years? | roscoe | 5.0 Mustangs | 5 | June 14th, 2007 05:44 PM |
| Ford explorer head and intake | nasty92LX | 5.0 Mustangs | 16 | March 22nd, 2007 11:53 AM |
| Explorer Heads? | 95stallion | 94-95 | 29 | December 24th, 2006 12:21 AM |
| explorer heads and intake | coreyfitz | 5.0 Mustangs | 14 | November 26th, 2006 05:09 PM |
