need some advice.
hey all im not new to the forum but new to this section.
i am almost 100% sure i found a notch to buy, just wondering if it is a good deal. i will be turning it into a drag car and hopefully able to drive it to a car meet or cruise as well. as for that i will discuss my plans later and see your feedback. the car i am looking at is a 93 coupe with a cowl with a custom dash. it has all of this as well 6 point bar 10 gal cell Yellow Top Optima battery in trunk 4:30 gear Moser Spool Moser axles Aerospace Rear Disc Brakes Southside Bar Lower Control Arms Stock Upper Control Arms QA1 Tube K Member QA1 Front Coilovers Billet Caster/Camber Plates MSD 6AL Box Autometer Custom Dash with Gauges tranny cooler w/ elect fan Welded sub frame connectors Drive shaft loop 5 Lug Conversion Weld Pro Stars 15x8 5.5 Backspace (255 radial, not drag radial) Weld Pro Stars 15x3.5 w/new Mickey Thompson Fronts Hurst Quarterstick for C4 5 inch HO Fibertrends Bolt On Cowl Hood Full Interior With Backseat, power windows work. Car has been repainted and looks good. NO RUST for 4000 doll hairs. it also comes with a C4, reverse manual valve body, TCI billet servo, Moroso Pan, and TCI 8" converter. but the c4 has been beat on as it used to be a tt v8 car. it has started out as a 4 cylinder. there pretty much nothing in the engine bay so i would need a wiring harness and everything else. |
any info would be great as to what to look at and watch out for. this is the first time im buying a used car.. and dont know much about fox bodies just the 3v modulars.
1993 Mustang
we'll find out when i come home from iraq.
im assuming this is a roller?
shut up before i punch you in the throat |
yes sir, i thought i mentioned that.
1993 Mustang
see if you can talk him down a little
thats a given with any kind of purchase.. what is a reasonable price for this stuff to go so i know whether im not getting stiffed.
found another fox instead looks like a better deal lemme know what you think. one of my plans was a 408. and this 1 has it. 1987 Ford Mustang Coupe w/408
1993 Mustang
really depends on you w/ that one. i mean if you would rather just buy a car already done, the second one would probably be the way to go. if you'd rather do the work yourself then the 1st one. id love to have the 2nd one lol
i just figure for another 3 grand why not get the 2nd one.
![]() i already told him to call me |
1993 Mustang
yea definetly
only thing is where the shifter is located, seems like he did some cutting, is there no way to get the shifter in stock location with a c4?
1993 Mustang
i couldn't tell you on that one, no experience w/ c4s
I do agree...If this one comes with the motor aaaannnnd its the motor you want then go get it. After my recent purchase I am partial to buying a car that is stock or close to it. Only because I bought a car that was modded and the guy I bought it from couldnt tell me much about it being that he got it from another guy. So I am still finding out things. That makes it hard to buy performance parts without stripping down the whole motor first.
But if he has all the details and receipts then go for it. LOL. And hell a 408, oh yea...sounds good to me. LOL.
302, Cobra upper and Lower Intake,UDP's,BBK Shorties with Flow Dumps, SMog Delete,CAI, 70mm TB, K&N Filter, Timing 14 degrees, Lowered 1.5, 3.73's, Nitto Dr's. "Its not that there is ever too much Horsepower, but not enough traction."
#14 | |
1993 Mustang
my dad picked up his 68 camaro almost the same way except the woman had got divorced and got EVERYTHING lol, ended up selling to my dad for $2,000
the guy is solid at 7000 for the 408 stang. im gonna see what i can pull i might have a new car!
yeah go for the 408 but make sure you hear it run before you make any promises listen for knocks ticks and see how she shifts
Both cars are pretty good deals I think. With the economy the way it is you will find alot of good deals on Mustangs out there.
You can fit a couple shifters in the stock location on these cars. I believe B&M makes a specific shifter for these cars and the Hurst Quarter Stick fits like a glove when you use the adapter plate from Holcomb Motorsports. With the Holcomb/Hurst set up you can use a stock 5-speed boot so the car looks like a 5-speed car. People relocate the shifters for two reasons, one is because they are idiots and can't figure out how to put them in the stock location and the other reason is because it is a better feel for some people to move the shifter back.
what color is the first one? because if it's black, then get that because black cars are faster than red cars
#20 | |||
trust me i love black, i have a black s197 with the porno red interior. did i mention this car was carbed?? any good readings for me on the subject. the car runs 6.80s in the 1/8, thats around 10.60s in 1/4 correct? he said it was a 1/8 mile car, i do 1/4 mile so i know i will need to make some changes. |
Threads Similar to: need some advice.
| need some advice! | Blk01ponyGT | The Clubhouse | 31 | June 7th, 2008 03:32 PM |
| need advice | tweeters97 | 5.0 Mustangs | 2 | March 10th, 2008 02:39 AM |
| A Little Advice Please... | 1FastFox | The Clubhouse | 9 | December 7th, 2007 02:44 PM |
| Need Advice | coreyflipp | The Clubhouse | 22 | December 6th, 2007 08:18 PM |
| New '96 GT need some advice | S10-92V8 | 96-98 | 13 | October 31st, 2007 11:21 PM |
