FORD RACING GT-40X TURBO-SWIRL ALUMINUM
Old December 26th, 2006, 02:48 PM   #1
stang94 is on a distinguished road
How good is this, would you guys say?
Features 64cc Combustion Chambers. Machined 356-T6 Aluminum With1.94" Intake And 1.54" Exhaust Valves And Valve Springs 240 CFM Intake Flow Rate and 170 CFM Exhaust Flow Rate Sold Individually
ANd what cam will work good with that also?
I have an Trick Flow U/L intake.. and can't afford the heads from TFS.
I am getting these really cheap..and wants to know if it worth it. Thanks
Old December 26th, 2006, 03:12 PM   #2
the reset of my mods are
70MM TB
BBK CAI
24# injector (not install yet)
U/L Trickflow (not yet install)
Trick flow stage 1 cam (not install yet, would that work with these heads)
BBK Shorty headers, with o/h x pipe and flows
I want a really good cam, to work with those heads if they are good to used, all suggestion are welcome.
Thanks
PS: I know i should save up for the TFS, but what are my options on these.
Giving Away For FREE PM ME.
FREE 351 Block, 90,xxx miles (Non roller block)
FREE 94-98 GT Hood (red)
Old December 26th, 2006, 03:27 PM   #3
95oldyeller's Avatar
95oldyeller is on a distinguished road
Re: FORD RACING GT-40X TURBO-SWIRL ALUMINUM
how much $$$ did they cost? from what i read there the exact design as the iron GT-40, just in aluminum form. so not really that much better, just less weight.
Go Tarheel's, your our men, if you can't do it!!!............................................. ...............................DAMN!!??
Old December 26th, 2006, 03:30 PM   #4
I am getting both for $650, but I can beat him down to 600 flat... if i walk with cash lol...
but compare to the TFS, on the scale from 1 to 10 how good are they, i'm sure they're not better.
Old December 26th, 2006, 03:33 PM   #5
i'd probably give'em a 6. but for $650, thats kinda hard for anyone to pass-up.
Old December 26th, 2006, 03:38 PM   #6
Ok, but my ? is how good are those heads compare to the Trick Flow TW on a scale from 1-10?
Old December 26th, 2006, 03:40 PM   #7
i think the GT-40's are a good head even though most people consider them "out-dated". but if u have the experiance, u could open up and polish the ports a bit and have a set of great heads. i wouldn't worry to much about the valves cause there decent sized if u plan on stickin with a stock "bore" 302... but thats just my opinion.
Old December 26th, 2006, 03:41 PM   #8
6 on a scale of 1-10
Old December 26th, 2006, 07:11 PM   #9
86er's Avatar
86er is a splendid one to behold86er is a splendid one to behold86er is a splendid one to behold86er is a splendid one to behold86er is a splendid one to behold86er is a splendid one to behold86er is a splendid one to behold86er is a splendid one to behold
i read an older mmff and they swapped those for a set of afr's picked up 77hp if that tells you anything
Just a truck
Old December 26th, 2006, 07:48 PM   #10
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
New or used? $650 is a hell of a deal new but I wouldn't give more than $450 used. You will need to mill those to get the chamber size down unless you are running a supercharger or turbo. If the heads are used I wouldn't put them on without a valve job and new springs.
Old December 27th, 2006, 01:51 PM   #11
They heads are used.. I am not gonna bother with it..
I do want a set of heads though.
I am gonna go with Trick Flow T.W
or where can I find info an afr's and are they better then the twisted wedge?
I"m need a cam to go with that too.. I want a mid-mean sounding cam.
I find.. http://www.jegs.com/webapp/wcs/store...10002_26553_-1
which one would you guys recommended?
I think I can come up with that $$$ (KEY WORD THINK) but which one?
Old December 27th, 2006, 01:58 PM   #12
95opal's Avatar
95 opalfrost gt
95opal will become famous soon enough
If you go with the 185s you have to have your pistons notched. Still no biggie. I have a set of 165s and a custom cam from ed at FTI waiting to go in. Give him a shout he will send you in the right direction, http://www.flowtechinduction.com/
5.0 magazines
94-04 performance mustangs feature car! Fall 2010
Threads Similar to: FORD RACING GT-40X TURBO-SWIRL ALUMINUM
ford racing aluminum driveshaft tjames V6 Mustangs 36 July 7th, 2010 10:35 AM
which ford racing cam do i have??? nba1341 5.0 Mustangs 20 November 1st, 2007 02:36 AM
Ford Racing thewayshemoves 99-04 22 December 29th, 2006 08:36 AM
Ford Racing S/C Skullman General Tech 8 September 29th, 2006 05:28 PM
