Timing Question???
Hey, I have an 88 Mustang GT. I swaped the motor with a brand new 302 short block. I was told it was based on a 94 cobra block, and i added the following:
Crane comp cam Trick flow twisted wedge heads 1.6 roller rockers hydraulic roller lifters trick flow push rods performer rpm intake msd ignition Holley 4150 hp series Carb 650cfm mechanical secondaries(no choke) My question is, i'm trying to adjust the timing as a starting to adjusting the carb because it's idling high. Does anyone know the correct timing for this setup or is it the same 10 degrees as stock? Can you also recommend what to do about the pulley, it's all rusted and i can't see the numbers and what type of timing light (i've heard some timing lights don't work well with MSD ignition. with that being said, i then will be off to adjust the carb after the timing. i took it to a mechanic a while back, and i was told that they can't get the idle down because it looks like someone drilled holes in the butterflies. i bought the carb brand new from summit. Is this the way the carb comes because it is a racing carb and is it too big for what i have ....or do you think someone altered it? I know there is a lot of questions here, but i've been dealing with this problem for a long time and i don't know what to do. Any help will be greatly appreciated . Thanks guys! |
You will have to play with the timing and see what the engine likes. You will need to clean the balancer up so you can see the marks. Spray around the carb with carb cleaner and see if the idle changes while its idling. You might have a vacuum leak. A 650 is not to big for that engine, it probably just needs some adjustment.
The reason someone drilled holes in the butterflies was because it was running rich at idle or had trouble getting a decent idle because of a radical cam. When that happens people to turn the idle up to get a decent idle to the point where the idle/air screws no longer work because the carb is now idling on the main circuit because too much of the transfer slot it exposed.
Anyhow, holes in the butterflies should have NOTHING to do with not being able to adjust the idle.
1982 GT (t-top) 351w(.060),10:3, ported & polished iron heads, 1.94/1.60 valves, BBK shorties & flowmasters, 274XE cam, stealth intake, mallory dizzy, stealth intake, 750dp, Edge 3700 stall converter, C-4, 4:10's Best E.T 12.79@103.55mph |
#4 | |
1) Replace the balancer with a new one or 2) Clean the balancer good and install timing tape that you can buy for about $5 A good starting point for timing would be 10* BTDC and go from there. A test & tune day at the track would really help you dial in the timing or a trip to the dyno
all motor
92 coupe
9.94@136.40
hey nyhigh- The cam card should spec the timing it likes, but I would try 13 degrees to start. Double check to make sure you have the right size pushrods (length).
RE
Thanks guys, i appreciate that.......what should i do about this crazy idle though....it's idling at 1500.....and for some reason when i give more than half throttle, the secondary butterfly lever on the passenger side of the carb gets stuck on realese of throttle and stays at 3500rpm ......Weird huh? I have to get out of the car and give the lever an extra push cause the engine is screaming.
all motor
92 coupe
9.94@136.40
Im a fuel injected guy, but have you checked the curb idle adjustment screw? I think there may be two- one for high idle/and choke. Check all positions of adjustment screws- curb idle, high idle, choke etc. check your fast idle lever,A/c idle speed adjuster, etc... And your throttle position. I don't know what your carb has, hope that may help.
Find out why the linkage on the secondaries is hanging up. It should all move freely.
I don't understand why you just can't turn the idle speed screw to get the desired idle speed. Silly question but are you turning the correct one?
You know what, i'm not even sure which one you mean....i know there are 2 flat head adjustment screws on each side of the carb, and than there are the float adjustments........i'm not near the car to look right now but where would the one your talking about be?
I'm not that good at the tuning thing yet so i appreciate the help. |
all motor
92 coupe
9.94@136.40
Try this |
The idle speed screw should be on the driver side next to the throttle lever.
The two small screws you see in the front are the idle/air screws. To set those, turn each one all the way in until the engine begins to stall and then turn it out about a half turn. Do one at a time! Set your idle speed first and then set the other ones like I just said.
The idle timing on a carb vehicle is not as important as the total. ASSUMING you have the correct centrifugal advance distributor, set the total, measured at 3500rpm, to 30*, and go from there. More than likley, this will give you 10-15 at idle, which is about right.
I think he's talking about the idle SPEED...not the timing.
Threads Similar to: Timing Question???
| Timing Question | USMC8511 | 5.0 Mustangs | 4 | June 19th, 2007 07:26 PM |
| Timing Question | bigbadtalontsi | 5.0 Mustangs | 4 | March 27th, 2007 11:17 AM |
| timing question | N02coupe | 5.0 Mustangs | 2 | March 27th, 2007 08:03 AM |
| Timing Question | sfarrah | 96-98 | 7 | July 12th, 2006 03:08 PM |
| Timing Question | Vamp89 | 5.0 Mustangs | 2 | July 5th, 2006 06:57 AM |
