351w
Old December 22nd, 2008, 04:45 PM   #1
shadowgames81's Avatar
87 Coupe
shadowgames81 will become famous soon enough
351w
How good is a carbed block from an 88 bronco? Like how much power can it handle and is it a roller??
Eats rice daily
Old December 22nd, 2008, 07:10 PM   #2
87 Coupe
no one?? Bigbootsy?Darell?turbolx?anyone???
Eats rice daily
Old December 22nd, 2008, 07:10 PM   #3
87 Coupe
I can pick one up already running for 350 but I wanna know if its worth picking up or if I should wait and try to find an older one.
Eats rice daily
Old December 22nd, 2008, 07:40 PM   #4
86_Notch's Avatar
1986 lx notch
9.98 @ 135
86_Notch will become famous soon enough
it's not a roller, but i'd buy it for 350 as long as it carries good oil pressure and doesn't smoke or knock.
" Spending money I don't have.... on things I don't need .... to impress people I don't know "
Old December 22nd, 2008, 07:45 PM   #5
87 Coupe
haven't gone and looked at it yet but he said its still in the truck, runnin, w/ no leaks or smoke. I'll believe it when I see it though. I just wasn't sure if it was worth gettin because I know the older blocks were stronger but can't find anywhere how much power this year block would be able to handle. I have an 89gt roller I wanna put a carbed 351w in and I have a c4 w/ a shift kit I was gonna throw a stall in and some 373 or 410's in the rear. Just wanna make sure I get a good block that can handle 600+hp down the road after I rebuild it.
Eats rice daily
Old December 22nd, 2008, 09:11 PM   #6
87 Coupe
ANy idea how much power an 88 block would handle?
Eats rice daily
Old December 22nd, 2008, 10:34 PM   #7
ryans88gt's Avatar
700-800 hp. Mostly depends on rpms and the rods you use. the blocks are good to 700+, but you will spin a bearing at much over 6800 rpms unless you opt for some main caps.
Old December 23rd, 2008, 09:31 AM   #8
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
88 Broncos had carburetors??
If it runs good it is worth $350. Probably not a roller block but you can put a roller cam in anything. You don't need to use 5 liter specific roller cams. Cam companies have been making roller cams for Ford engines since long before Ford even thought about putting a roller cam in a Mustang.
Old December 23rd, 2008, 11:19 AM   #9
Big timin' in a small town
Drick's Avatar
2004 FX4 F150, 86 GT
i was wondering the same thing Pretty sure 88 broncos are EFI
FX4 Crew
Crew member #1
Don't take anything I say to heart, I don't try to come off as an asshole. It just happens
Old December 23rd, 2008, 11:57 AM   #10
MEMBER #334
stangfreak is a glorious beacon of lightstangfreak is a glorious beacon of lightstangfreak is a glorious beacon of lightstangfreak is a glorious beacon of lightstangfreak is a glorious beacon of light
Send a message via AIM to stangfreak
Ford F series article (applies to Bronco)
1988 saw the SuperCab offered in a shorter (139-inch versus 155-inch) wheelbase and all engines were now fuel injected, including the 5.0- and 5.8-liter V8s.
[SIGPIC][/SIGPIC]
[SIZE="4"]"This just in....14.79 @ 92.15 is not fast"[/SIZE]
Old December 23rd, 2008, 12:31 PM   #11
M L Struck's Avatar
85 GT/86 SVO/2010 GT500
M L Struck will become famous soon enough
think everything went efi in 86
Old December 24th, 2008, 02:31 PM   #12
87 Coupe
Ok guys I'm not saying it came w/ a carb. that is what I want to on it. I don't want EFI. Pretty sure that means the guy already swapped it. Just wanted to know how much power it could handle and if I should get it or not cuz I hear how the older blocks were stronger but didn't know how strong the newer blocks were. Thanks for all the help I think I'm gonna check it out and prolly pick it up.
Eats rice daily
Old December 26th, 2008, 02:35 PM   #13
Stangzilla's Avatar
Stangzilla is on a distinguished road
Well not sure on the exact specs on the 88 block, but I do know that DSS uses only 87 or later 351w blocks unless its a Lightning block. The strongest 351w blocks are the ones than have the 2 piece rear main seals. Lots of nickel in those old pieces...
Today, I found out that when I masturbate at night while watching internet porn I cast a huge shadow on the curtain and the entire street is able to see it.
Old December 30th, 2008, 09:04 AM   #14
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
I don't want EFI.
That's too bad.
The main thing is the earlier blocks are thicker. All of the newer (80s and up) blocks are thin wall castings to save weight and cut costs. The cylinder walls are thiner and the main webbing is thinner on the newer blocks. But even the newer casting 351W blocks can handle a fair amount of horsepower.
Old December 30th, 2008, 08:57 PM   #15
87 Coupe
I'm just wanting to toy around w/ a carb this go round and might swap back to EFI later.
Eats rice daily
Threads Similar to: 351w
351w justinsstang 5.0 Mustangs 10 April 17th, 2008 03:50 PM
351w javier351lx 5.0 Mustangs 1 May 14th, 2007 11:53 AM
351w javier351lx 5.0 Mustangs 0 May 13th, 2007 04:35 PM
351w FastBack71 94-95 6 February 4th, 2007 03:40 PM
351w terribleonexx88 5.0 Mustangs 11 December 31st, 2006 01:08 PM
