#21 | |
#22 | |
#23 |
1991 mustang 5.0
I put 2.75 quarts in. Maybe 2.85. I guessed because I didn't have a jack or jack stands. Shifts fine though so I guess I'm fine
#24 |
Look Ma! My First Post!
you need 4 qts of atf fluid
#25 |
The Big Spoon
88 5.0 5 Speed Notch <><
never fast enough
#27 |
1990 mustang gt
eventually
when do you get the vibration?
1990 gt 5.0 Mac Performance 76mm straight shot intake 70mm Accufab tb and egr spacer Trick Flow Track Heat u/l intake 3.55 gears MSD distributor, Blaster Coil, and 8.5mm wires |
#28 |
1987 GT
13.19 @ 107.02 (street tires)
200k miles, huh. How often are you supposed to change fluid in a T5?
#29 | |
Holy Dick Castle!
1988 GT VERT (Sold :(
'Cause she's got a... GRRRREAT ASS!
I have had my car for 5 years and I just had it changed today. Who knows how long it was before that. All I know is it didn't smell burnt when I bought it.
I haven't put 200K on it though
#30 |
The Big Spoon
never fast enough
I change mine once a year for good measure.
#31 |
'93 GT HATCH catlesssssss
Fast?
so to change the fluid out, you have to take the shifter off and pour through there???? i have a man trans.... and witch side is the drain plug???? the one on the pass side right??
#32 |
Mine was leaking through the speed sensor for a long time so I was always adding fresh fluid
#33 |
The Big Spoon
never fast enough
#34 |
The Big Spoon
never fast enough
Lower passenger side. Yes that is correct. the upper one on the same side is the fill port. It is a pain to fill it through there without a little pump set up. Most people fill it through the shifter because it is easier. take the face plate off of your stereo first because you may end up punching it when you take the shifter out. I punched my a/c controls. my stereo wasn't installed at the moment.
#35 |
The Big Spoon
never fast enough
#37 |
1993 Mustang GT
I've had mine for over a year, never changed it, put over 15k on it....
Though I don't know when it was changed ever. |
#38 |
My stock 91 with almost 160K and 20 years was changed ONCE since new. Wow, maybe I should change it again.
Threads Similar to: Transmission fluid change!
| Manual transmission fluid change | Saleen0101 | 99-04 | 27 | August 10th, 2011 08:29 PM |
| transmission fluid change question | stang300a | V6 Mustangs | 14 | December 16th, 2008 09:52 PM |
| Tranny fluid change... | 02S281 | 99-04 | 8 | August 4th, 2008 02:42 PM |
| Trans Fluid Change | 90Stang | 2005 - 2010 | 0 | March 10th, 2008 10:55 PM |
| Tranny Fluid Change | Montanasvt | 99-04 | 21 | February 8th, 2008 05:01 PM |
