![]() iTrader: 1 reviews
Which tire size?
Which tire size do you think I should use.I am looking at 275/50/15 or 275/60/15.They will be on a 91 coupe.The rims are 15x8 Draglites with 5.5 b/s. I have aftermarket rear upper and lowers,4 cyl rear springs and the car is not lowered.
91 LX coupe,Aluminum heads,Steeda roller rockers,Typhoon Intake,F303 cam,Cold Air Intake,Tremec T5, Cobra R Rims, MSD ignition, MSD distributor, FMS Cobra LSD w/3:73 Gears and 31 spline axles. |
1986 lx notch
9.98 @ 135
the 50s are @ 26 inches talll and the 60s are @28 inches tall . i say go with the 50s unless you have 456 gears
![]() " Spending money I don't have.... on things I don't need .... to impress people I don't know " . |
I have 327 gears in it now but I have a set of 373's to go in.
1986 lx notch
9.98 @ 135
go with the 275-50-15s
Will i have to remove the quad shock.I saw where some people flipped them.
#6 | |
1992 Lx
11.39@119.24
on 9" wide rims i didnt have to, you might
1989 LX coupe 5.0L
aftermarket lowers alone will suffice. throw the quads in the garbage
[SIGPIC][/SIGPIC] [SIZE="4"]"This just in....14.79 @ 92.15 is not fast"[/SIZE] |
g
ive got 295/50/15's under mine and they dont rub. 1990 coupe with 4 cylinder springs in the rear with 15x8 weld rims
Threads Similar to: Which tire size?
| tire size | mustangboy8909 | 5.0 Mustangs | 10 | January 7th, 2008 02:19 PM |
| tire size | dark-samurai2 | V6 Mustangs | 24 | August 17th, 2007 12:02 AM |
| Tire Size | hommie | 5.0 Mustangs | 11 | December 28th, 2006 06:13 PM |
| Tire Size | notsoslo5.0 | 5.0 Mustangs | 4 | October 13th, 2006 05:35 PM |
