How to fix my seat
how would i go about fixing my seat. its doing the famous leaning to one side those seats are known for doing. and the seat is broken even more now. i cant even tilt it up. so it leans back really far and to one side. and it wobbles alot too. lol damn.
is there a seat repair kit out there or something i can get at a hardware store and instruction on how to fix it?? please help a brotha out.
Too often, We lose sight of life's simple pleasures. Remember, when someone annoys you it takes 42 muscles in your face to frown, BUT, it only take 4 muscles to extend your arm and bitch-slap that Mother@#?!&! upside the head!! |
The easiest way would be to find another seat and weld some subframe connectors under the car that have the crossbrace that supports the seats.
1982 GT (t-top) 351w(.060),10:3, ported & polished iron heads, 1.94/1.60 valves, BBK shorties & flowmasters, 274XE cam, stealth intake, mallory dizzy, stealth intake, 750dp, Edge 3700 stall converter, C-4, 4:10's Best E.T 12.79@103.55mph |
yeah i think im just going to get new seats for it. i cant really drive it the way it is now with out putting down the rear driver side seat to push up on it. so since the interior is fully black im going to put in 94-04 Black leather seats in it.
what I did was just got a junk seat out of the junk yard and pulled it apart and just used the back seat pan and put my foam and seat cover on it the worst part of the whole job was popping the clips to pull the head rest
If you remove the rear seat cover and foam from the frame, you will see where the frame has broken and seperated at the spot welds. it's easy to fix the seat frame with a little straightening and welding
1990 LX hatch
twist 2 go is right. take off your seat cover and from the back youll see the airbag. you need to push the passenger side of the seat back into place. then reweld the spot welds, next I would run a bead along the seam were the two sheets meet. I have done this three times with one seat because I diddent weld it thouroughly, the more welds the better! Also stuff a bunch of wet rags between the foam and the seat metal. The foam in the seats goes up like paper.
Threads Similar to: How to fix my seat
| seat removal | tommyboy | Visual | 4 | August 7th, 2007 11:34 AM |
| Car Seat | 07gtmustang | 2005 - 2010 | 2 | August 7th, 2007 04:06 AM |
| Seat question | firefly1241 | 5.0 Mustangs | 7 | December 27th, 2006 11:49 AM |
| Seat Changes | Sithlord | V6 Mustangs | 2 | June 26th, 2006 08:00 PM |
