Discussing Cam and head swap I need help!!!!! in the 5.0 Mustangs Forum. I have a 1989 mustang LX Convertable I want to do a head and cam ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
Cam and head swap I need help!!!!!Suspension u/L udjustable control arms 4:10 gears 70/30 lakewood struts in front and 50/50 in the back. I have full length subframe connecters with a 8 point rollbar the motor has GT40 intake 75mm throttle body with a 70mm mass air and underdrive pullies, I also have long tube headers with X-pipe and magnaflow 3inch mufflers with tail pipes. i also have a cold air intake in fenderwell. So far my car has run the best of a 13.30 even. but here is my delemma I want to either go trick flow twisted wedge heads or edlebrock RPM or airflow research. I was wanting to go with the TSF cam I am not sure of the number but they advertise three in summit it is not the first one but it is the second one but i do not want to loose horse power and actually go slower than I am right now. But I definantly want a Lope and not just when it is cold. Let me know what you think I would really appreciate it. |
95 opalfrost gt
Any one of the heads you listed w/ a cam matched to your heads and intake will produce some nice hp. If you cant decide on a cam consider a custom. Talk with either Ed Curtis at http://www.flowtechinduction.com/ or Jay Allen at http://www.camshaftinnovations.com/
So do you think the TFS stage 2 cam shaft is to big and also can I run the 202 intakes with this cam and not slap my stock pistons. What would be better is if some one could tell me how big I can go with the stock pistons with out any damage from slapping my pistons. Thanks again Kevin B.
Feb 08 ROTM
1990 Mustang LX
9.36@143 mph
TFS stage 2 cam and a set of Twisted Wedge heads would be my choice. The Twisted Wedge heads are the only heads on the market that will let you get away with a 2.02 intake valve and stock pistons. With that cam and those heads along with your current parts you should have no problem running mid 12s.
Racing in memory of Dave Bandt 11/19/69 - 3/23/08 "he's traded his wheels for wings" Professor of Natural Aspiration ![]() Thanks to: Artie at Trick Flow, Dave at Team Z Motorsports, Brian at Total Engine Airflow and Harold at Furo Racecraft |
Thanks for all the help I am going to go with a trick flow cam part # TFS-51402001 and a set of Trick flow Twisted wedge heads. Thanks again
Kevin. |
Asshole Moderator
noob question, whats the diffrence between the heads with the o-ring groove, and without the o-ring groove?
2004 SVT Cobra 2000 LS1 Camaro
#7 | |
Feb 08 ROTM
1990 Mustang LX
9.36@143 mph
A couple more Questions. So do you think I can get away with the stage 2 trick flow cam and the twisted wedge heads? If I do not have to check the valve to piston clearance it would make me really happy! Or what if I went with the stage 1 cam and just ran 1.7 rockers would that work with no problems? Thanks Kevin
#9 | |
Feb 08 ROTM
1990 Mustang LX
9.36@143 mph
Just my .02 cents, but if you have the money, and can wait forever, I'd go with the afr heads. they flow better than any others, just know the setup you're lookin' for.
What heads in the AFR would you go with. Remember I am working with stock pistons. thanks
#12 | |
Feb 08 ROTM
1990 Mustang LX
9.36@143 mph
what are u lookin' to end up with? Are you gonna spray? NA? blown? If ur lookin to keep the stock block, it can only handle about 400 horses. If you're thinking about possibly upgrading and getting serious sometime in the future, I would seriously consider going with your bestbet and not waste any money. If you just want a quick street/highway car,go with the middle of the road and save money.
AFR offers custom setups. Figure out what u wanna ed up with, then start deciding how to go. SBF AFR heads are expensive, you can choose cc size, type of porting, upgraded xhaust valves, stock size valves - or longer, straight/angle plug, standard xhaust or spread port. AFRs are more for the racing minded. If you just want quick- the Twisted wedge package may be best. JUST MY OPINION |
#14 | ||
I checked AFRs site. The cnc ported twsted wedge heads actually dynoed 5 hp. more than the comparable afr's. I stand corrected
#16 | |
Feb 08 ROTM
1990 Mustang LX
9.36@143 mph
I own afr heads with a custom setup. Their springs and retainers suck but after upgrading that they're sweet. expensive but sweet. I have a big blower so im running 210cc with a custom setup. It's being put together right now. i think all my friends run afr or just about and they flow great.
and, when my notch was mainly stock bottom/top end with a bunch of boltons, with a head job- new springs, ported, etc. I raced a gt with twisted wedge heads and won by about 2 leghths. i wasn't impressed.
#19 | |
Feb 08 ROTM
1990 Mustang LX
9.36@143 mph
I am getting the CNC ported TW heads....I think it will be money well spent.
393 dropping in a foxbody near you, very very soonMilitary Crew E-3 Combat Engineer |
Threads Similar to: Cam and head swap I need help!!!!!
| 4.6L PI Head Swap Kit | slvrbllt98GT | 96-98 | 5 | June 14th, 2007 03:29 PM |
| head swap | Mustang RacR94 | 99-04 | 9 | April 25th, 2007 05:27 PM |
| PI Head Swap and Transmission Swap | jEEd | 96-98 | 6 | January 6th, 2007 02:37 AM |
| Head Swap | wikdsvt | 5.0 Mustangs | 5 | October 10th, 2006 06:19 PM |
| 5.4L Head swap??? | rwk3072 | 96-98 | 7 | July 23rd, 2006 12:40 AM |
